Gen II Backup Camera - replace OEM with aftermarket
Discussion in 'Gen 2 Prius Audio and Electronics' started by RustySynapses, Oct 28, 2019.
  1. RustySynapses
    RustySynapses Junior Member
    Northern Virginia
    I have a 2006 Gen II Prius, with JBL, NAV and backup camera. I'd like to replace the backup camera with something newer that has much better resolution (every time I get in a rental car I get jealous). I'm planning on replacing the OEM stereo with a new head unit, so that side shouldn't be an issue. How hard is this:
    (1) Physically, to fit a new camera where the existing one is? Is there anything standard about the existing camera or how it attaches?
    (2) Wiring - is a new camera going to work with the existing wiring?
    I will probably use a professional installer for the stereo, so I'm hoping this is something really easy to add to the job.
  2. ydpplqbd
    ydpplqbd Active Member
    551
    254
    Good question on using higher resolution backup camera in Gen2 Prius. I am thinking about doing the same thing.
