Gen II dead -- please help me diagnose the issue
Discussion in 'Gen 2 Prius Main Forum' started by JoJo_NC, Nov 13, 2013.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    As I said earlier removing the 12 volts blows out all stored error codes which sometimes come in handy if the repair is mis-diagnosed and you need to get on track to what the real issue is. Also blows out the radio presets and the auto window settings. Both very easy to set.
    Remove and replace the throttle body should take 2. hours. Fairly easy. 4 nuts 2 hose clamps, and 2 electrical connectors. That includes a good cleaning of the used one before installation. Being able to clean the used throttle body out of the car is quite handy. Please take advantage of it.
    If not you may be right back where you started.
    Independent mechanic I use charges $80 an hour so that job is $195 with supplies and tax.
  2. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    where are you located?
  3. usnavystgc
    3,159
    990
    Tucson, AZ
    Well Jojo, what I would do then is tell the shop you want the old one, clean it up and get it operational and sell it on Ebay to offset the cost of the used one. lol
  4. dpeverhart
    dpeverhart Member
    126
    23
    I
    I think your mechanic is on the right track. I just had the throttle body go out on my 2005 with 117k miles. Mechanic tried cleaning it but it would not work and needed replaced. I was throwing codes P2111 and P2103, both relating to throttle body. Car would start and run but when given gas would not rev. After idling like that for a while it threw a code P0A80 indicating a problem with the HV battery.
    We picked up a used throttle body from a junkyard for $200 with a 1 year warranty and swapped them out. Performed a force charge by making the Prius READY, shifting to D, then holding the car stationary by applying the brake pedal with your left foot while flooring the accelerator pedal. It's run fine ever since. No HV battery problem or any codes. The throttle body swap took about 10 minutes.
    edthefox5 likes this.
  5. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Excellent post.
    Thanks to your post I now see why Jo Jo still is throwing the P3000 because the Hybrid Battery is very low and the system is not happy with an idle charge at that low of a charge. Software is commanding the engine to fast idle to charge the battery and it refuses so it throws that battery code. I suggest the op do the same as you did.
    dpeverhart-Do you know what failed on your tb? Was the throat corroded or the motor failed?
    uart likes this.
  6. JoJo_NC
    JoJo_NC Junior Member
    16
    Thanks for your response. Good to know we're on the right track thus far. Can you tell me more about the force charge:
    How did you know it was necessary? were you still getting the P0A80 code after the throttle body replacement?
    Did you do this immediately after replacing the throttle body?
    How long did you have to floor it like you mentioned?
    How did you know the issue was resolved - did the code clear on its own after doing the force charge, or did you have to "re-boot" in order to clear the code?
    Finally - dumb question - how did you get it into Ready? Just starting the car as you normally do? (I've never thought about having to get it into Ready)...
    thanks
    Questions for all: should the codes clear automatically and immediately after replacement of throttle body? or is a re-boot required to clear codes? the mechanic has been reluctant to do a re-boot (by disconnecting 12V battery) prior to throttle body replacement, I assume he doesn't want to lose some sort of memory in terms of the codes. If the two codes related to throttle body clear but it's still throwing the P3000, what's my next move -- is that when I should attempt force charge as mentioned by dpeverhart?
    thank you! all advice greatly appreciated. fingers crossed for tomorrow. oh and I'm in the DC suburbs to answer question above.
  7. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Hi JoJo. When the throttle body is fixed and the Prius first started, it will automatically run the engine at a fast idle for several minutes to recharge the HV battery (with the transmission in "P"). It will then cut out when it reaches 2 or 3 bars. As Ed said, it's probably been trying to do this, but unable to due to the dead throttle body, and hence the P3000 code.
    In addition to just leaving it "P" and letting the Prius automatically bring it back to a safe (but still fairly low) level of charge, you *can* do what's called a force charge. To force charge you place the transmission in "D", and with your left foot *firmly* on the brake, you apply moderate accelerator pedal until the engine revs enough to show green charging arrows into the battery. Using this forced method you can bring the battery all the way up to 7+ green bars if you want to.
    To be honest though, I personally recommend merely placing it in "P" and letting the Prius automatically bringing up to 2 or 3 bars at fast idle. When it finishes this and the engine shuts off, then just take it for a drive and it allow it to recharge the battery to 5 or 6 bars as per usual.
