Gen II scan gauge inverter coolant temp???
Discussion in 'Gen 2 Prius Technical Discussion' started by cvincent, Oct 28, 2012.
  1. cvincent
    cvincent Junior Member
    76
    arizona
    I have read every thread i can find on this and i am not finding the codes to run the inverter coolant temp for gen II
    Is anybody actually running that on their scan guage?
    Mine is updated with the latest software
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I just checked Adrian Black spreadsheet that I have for SGII and do not see an inverter temp for the Gen II.
    Sorry.
  3. cvincent
    76
    arizona
    Thank you, I programmed in the 2 mig codes and they seem to be working
    But I am not at all sure what they represent
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    There is no "inverter coolant temperature sensor" on Gen2, therefore no way to display it by SG-II.
    Ken@Japan
    [email protected] likes this.
  5. pjc
    pjc Member
    139
    46
    Bloomington, MN
    I got these codes from another thread and they seem to work on my SGII. They do need the updated (4.x) firmware.
    MG1 Inverter Temp 07E221C3 010702EA0323 4808 00090005FFC6
    MG2 Inverter Temp 07E221C3 010702EA0324 1808 00090005FFC6
  6. Patrick Wong
    18,200
    6,500
    Hi Ken,
    How does the hybrid vehicle ECU know when the inverter coolant circulation is impaired, and that it needs to log DTC P0A93?
  7. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Hi Patrick,
    I don't know. :)
    But, there are only two sub code, 346:water pump malfunction and 347:cooling fan malfunction, in the DTC P0A93, no direct coolant temperature related.
    Ken@Japan
  8. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    How does Priidash report inverter and DC to DC converter temps if there are no sensors.
  9. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    There are inverter temperature sensors for MG1, MG2 and DC-DC converter, but no coolant sensor on Gen2.
    Ken@Japan
  10. Britprius
    5,194
    1,921
    Thanks for the clarification.
  11. Britprius
    5,194
    1,921
    Sorry Ken your reply does not make it quite clear but there are five sensors in total.
    (1) inverter 1
    (2) inverter2
    (3) dc to dc converter
    (4) MG1
    (5) MG2
  12. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Three inverter sensors and two MG sensors, total five.
    Ken@Japan
  13. Patrick Wong
    18,200
    6,500
    OK, I understand there are three inverter temperature sensors, but no sensor for the inverter coolant itself. That makes sense: if any of the five inverter/MG sensors exceed the high temp limit, then hopefully the skid control ECU will log an appropriate DTC.
