Gen III 200,000 Mile Club
Discussion in 'Gen 3 Prius Main Forum' started by palmer976, Oct 8, 2012.
  1. Joaquim Silva
    Joaquim Silva Junior Member
    31
    30
    Lake Havasu City AZ
    My 2013 Prius 2 hit 200K mile today. Here is the history: New HV battery at 184K for $3,105 and just replaced original lead acid (made in Japan) battery this morning myself. Nothing other than regular maintenance, filters, wiper blades, tires. Front rotors and pads at 180K+, rear pads are still at 4mm out of 8mm. Oil change every 10K. I have not replaced spark plugs, radiator fluid or transaxle fluid. It does not burn oil yet (knock on wood). My next thing is to do these things. Dealership replaced HV battery filter and cleaned its fan when exchanging the HV battery. Link:
    Tbkilb01 and shawn.ne like this.
  2. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Joaquim Silva congrats on 200k! I was wondering if you have had any thoughts on why your HV battery died? I mean, it's obviously got age and use on it but not too bad. Just curious if anything has happened that you suspect could have caused it to go bad?
    Thanks!
    Stephen
  3. Joaquim Silva
    31
    30
    Lake Havasu City AZ
    I am convinced that it was the mileage. It lasted four years and one month, so it was not age.
  4. Tbkilb01
    Tbkilb01 Active Member
    216
    187
    Louisiana
    Fluid needs changing due to deterioration etc...
  5. Mendel Leisk
    41,254
    Yup it's on the Canadian Toyota schedule now. Toyota USA brake fluid is apparently immune still? (n)
    Raytheeagle and m.wynn like this.
  6. Keepdriving
    Keepdriving Junior Member
    35
    27
    Palatine
    2010 Prius III
    1) No, but Check Hybrid System light came on at 192K past summer. Have been driving with bad battery since.
    2) No
    3) No
    4) Yes, changed front brake pads after 120K
    5) 53 summer 46 winter
    6) 15K Synthetic 0W-20
    Raytheeagle likes this.
  7. Keepdriving
    35
    27
    Palatine
    #47 Keepdriving, Mar 25, 2018
  8. Tbkilb01
    216
    187
    Louisiana
    2010 prius
    Yes to all the above.
    OCC done, really needs it on all of em! rerouted longer pcv hoses, brakes at 180k, transaxle fluid change and really stunk at 165k, changed pcv at 165k, new spark plugs at 165k, 12v battery now a yellow top, original lasted 7-8 years. change oil every 10k mobile1 full synthetic
    Burns 1/2 a qt. by then if I don't top off, Intake cleaned out, egr cooler cleaning, intake manifold cleaning, cleaned throttle body. New wipers, brake fluid flush, recently replaced 14 modules and then 6 more for fun! I over ordered! Use the wonderful HybridAutomotive system to charge balance and discharge traction battery. Ive always gotten a steady get 50 mpgS,Even as battery failed one really cold day! The computer really lnows what to do! Drive and enjoy!
    There really isn't a better car built! That I own.
    #48 Tbkilb01, Mar 25, 2018
  9. JustTiffany
    JustTiffany Junior Member
    Carrollton, TX
  10. RobinGV
    RobinGV Junior Member
    grass valley ca
    What happened to this thread?
    272,000 Miles + and going, and going.
    New HV battery from Project Lithium at 170,000 just because...didn't need it.
    New 12 volt battery due to trailer wiring box short and killing the perfectly good one at 220,000
    Head Gasket at 166,000 It needed it when I purchased the car in 2021.
    Original brakes,
    Spark plugs at 200,000 and again at 240,000 and again at 270,000. The 2nd set was a cheap brand.
    Transmission fluid at 180,000 and with every other oil change until it was red, not black on the change.
    Mobil 1 Hybrid 0w-20 as needed. Sometimes 5000+ miles, sometimes less.
    I tow a trailer often and have towed 2000 LBS hundreds of miles through the mountains. Thousands of miles with a heavy trailer. The rock quarry guys take pictures. I don't even believe it!!
    QS2 Quantum VVT Solenoid made a huge difference at 230,000 Highly recommend this product.
    New Radiator and water pump at around 240,000 because I changed the fluid and didn't burp it right so I through unnecessary $ at it until I read Mendel's thread.
    Swapped the ECU with one pre-programmed with latest software updates at 271,000 due to a weird shifting issue. It helped and bumped the MPG's up a fraction. Hard to tell because now I drive faster :)
    Towing a trailer MPG is about 32-35 MPG. Without the trailer 40-45 MPG.
    Obviously I am rough on vehicles. This little Prius has taken the abuse better than any other vehicle I have owned. It is a better "truck" than my trucks.
  11. MikeDee
    MikeDee Senior Member
    1,576
    596
    San Francisco Bay Area
    What, nobody cleaned the EGR system? Huh...
  12. RobinGV
    grass valley ca
    Yes, Twice. Once with the new head gasket 166,000 and again at around 238,000 along with an oil catch can and ready to do it again at 273,000. Forgot to mention that.
