Gen III Prius Center Bore Dimension
Discussion in 'Gen 3 Prius Technical Discussion' started by enigma88, Sep 19, 2012.
  1. enigma88
    enigma88 Junior Member
    34
    Alberta, Canada
    I am planning to get steel rims for my 2011 Prius (winter is coming). I heard it's better to get hub centric rims so I want to know what center bore diameter for a Prius is. I read it's 54.1 mm for Gen II Prii but wanted to make sure if this is the same for Gen III.
    Also, do you think it'll be very expensive to get hub centric wheels? Would I be better of getting lug centric rims and purchasing the spacers?
    Thank you for your time.
    Cheers!
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I believe it's still 54.1 for the gen 3.
