Gen III - Rodent Damage - $900.00
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PhiloMcGiffin, Feb 1, 2011.
  1. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    I must be missing something - the link has to mostly do with the GenII Prius (though the back looks the same).
    I took off the side panels for soundproofing, and took care of the rear entry (mesh).
    My worry is the front. I still haven't seen details on how to keep them out of the air vent system (where to put the wire mesh under the hood).
    Since the first post on the GenIII a year ago, I've bought many tons of DCON green blocks - put them everywhere in the garage - and they do seem to work - every now and then you see some nibble marks...
  2. PhiloMcGiffin
    PhiloMcGiffin New Member
    NE PA
    I appreciate all the constructive comments... But please remember; as I said in my original post... The car sits outside (the garage contains a Corvette and pristine VW Super Beetle convertible) all the time... There is nothing to keep clean... Our yard, like the VW is pristine. My wife loves all animals, so traps of any kind are out of the question. I'm thinking some kind of pepper spray to make the wiring taste less palatable?
    The block off strategies mentioned by others seem focused on keeping pests out... Not really applicable in this case since the air box was attacked from the outside.
    I'm writing this message from the waiting room of the dealership...as the new air box is currently being installed.:)
    52,878
    could you wrap the whole airbox in mesh?
  4. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    Large grid wire mesh can be bought at Home Depot, and will keep them out of the airbox if placed over the air intake. A large grid mesh (1/4" or more) will not block the airflow enough to notice.
    or get a cat.
  5. LeadingEdgeBoomer
    289
    29
    New Mexico
    Search doesn't reveal a thread, just additional anecdotes, apparently. Do you have a pointer?
    We have at least one semi-resident coyote, maybe that helps my cars. I occasionally have to dispose of furry critter residue in the driveway.
  6. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    rrolff:
    Try a live trap. Set it under your car every night. If you catch one just drop him off some place on the way to work. You can buy these electronic things that keep rodents away as well.
    Cheers:
    Hal
  7. rrolff
    1,610
    246
    So Cal
    I used to use the live trap method - then I would put it in the bathroom with our cat. After a while, the cat got its exercise, and I ended up with a bit of mess to clean up.
    Since then, I've decided it's far more humane to throw tons of poison all over the garage (high, low, drawers etc).
    While I don't have any more mouse/rat problems, i'd still like to learn how to block the HVAC air intake to the car - just in case....
  8. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
  9. Launch Vehicle
    Launch Vehicle Junior Member
    82
    Missouri
    OK - now you guys have me really worried. Just found a bunch of fluffy fibrous material nestled on top of the oil fill cap. Stuff is so white - and so very clean - it looks almost like shaved ice or frost. And it looks new.
    We never had this problem here before.
    I'm afraid to even think of where this material came from. I'm hoping it was never part of the inside of our 4-1/2 month old Prius. Toyota touts its use of recycled organics. I hope they at least removed any tasty aroma.
  10. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    Just think, if they got in your car, where are they in your house right now and what are they doing.
  11. PhiloMcGiffin
    NE PA
    UPDATE
    Rodents Attack my 2010 Acura ZDX...
    These little buggers aren't satisfied with my Prius, now they've attacked the underside of the hood (insulation)... both cars get driven almost daily. Its been well below freezing every night for the last two months... there's no evidence of mice in the garage, or the house... no food or garbage outside. Just two "tasty" cars sitting in the driveway as they have been for the last year or so...
    The exterminator is coming tomorrow... I'll let you know what he says.
  12. dhunt
    dhunt New Member
    Woodacre
    Sorry to hear about your rodent damage, but I'm envious of your "service technician who made you a three-wire section & spliced the MASF wiring" for you. I had only two wires on the main wire harness that goes to the whole hybrid system get chewed, along with lots of fluffy white material chewed....the tech folks at Toyota told me the wires were not splice-able and they had to take the car apart to fix it. I pick up the car today with a $6,500-plus bill. This has got to be a design problem when your car can be taken down by a rodent!
    Car sits outside in front of the house, on the street.
    Does anyone know how I can stop this from happening again (without putting poisons out - lots of neighborhood pet cats in my area)?
    Thanks in advance for anything that will work.
  13. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    Man, You got ripped off Big Time
  14. Launch Vehicle
    82
    Missouri
    Dhunt, did the service tech ever identify what the fluffy white material was - and where it actually came from?
    You have me deeply worried here. I had the exact same stuff nested on top my oil-fill cap.
  15. esoniat
    esoniat Junior Member
    79
    Marietta
  16. Launch Vehicle
    82
    Missouri
    Can't find any missing insulation - so far. My "pile" was frosty-white, very clean, and silky in texture. Nothing like that exists in our car port.
    I'm worried that in its drive to create a green vehicle, Toyota may be using recycled, organic-based materials to insulate critical wiring that vermin find irresistible to munch on...
  17. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    I was going to suggest those high frequency sonic devices, but those are plugins for the garage. They do work. I have them in the house and cellar as well.
    One thing that's a no-no. Never leave food in the car (even crumbs), or any windows open. That doesn't seem to be the problem here, which makes it kind of scarey parking outside overnight.
    Sounds like this is a good application for poison traps--where the bait is inside housing and larger animals can't get to it. Never put these things in the house, though! The mice die in the walls-no matter what the exterminators tell you.
  18. dhunt
    dhunt New Member
    Woodacre
    This happens all the time. The Srvc team said another one came in the same day I picked up my car. They've done several just this month. Just takes one $3,000 part and 23 hours of labor to rip apart your car and put it back together. Good job...lots of work. Bummer.
  19. dhunt
    dhunt New Member
    Woodacre
    Yes, the white fluffy stuff was from the fender liners on both the left and right front fenders. Makes a great nest for rodents. You should get it inspected before they do more damage and get down into the door walls.
    Found a repellent that actually seems to be working. It contains pouches of balsam fir bark - very strong odor (got it at the local hardware store in the rodent repellent area). I put it under the hood each night when I park my car for the night and take it out and put it in a sealed container when I drive somewhere. Also put double-sided foam strips inside the engine compartment and covered it with cayenne pepper. No gnawing yet...and it's been a week.
  20. Launch Vehicle
    82
    Missouri
