Gen III with DRL module, lights turn on randomly when car is OFF!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by doublesman, Jan 25, 2012.
  1. doublesman
    doublesman Junior Member
    Toronto
    My Generation 3 has a DRL module installed by Canadian Tire here in Ontario. The module is made by Hamsar .
    The problem I have is that every so often when I look out the building where I work I would see the bloody headlights on. I also timed it, it stays on for about 10 mins and goes off . Now I do not know how often this happens other than I have seen it a few times since I had the DRL module put it .
    Would any one have any input at all on this ??? I could go back and make them undo the work saying that it is faulty .. but then they would probably want me to go to the dealer to have it redone (since it was a requirement to have the vehicle pass inspection to be registered in Canada) , which is $$$
  2. jaredy
    jaredy Member
    162
    SoCal
    OEM DRL RELAY, running light 8264247020
    I START A THREAD FOR OEM DRL RELAY FOR MOD AS CANADIAN VERSION OF PRIUS, BUT THERE IS NO ONE WHO JOINS FOR THIS PROJECT. YOU MAY START IT FOR US. TO TOYOTA SERVICE, I HEARD SOMEONE HAS DONE THIS IN CANADA WITH US PRIUS. :welcome:
  3. robby3
    robby3 Member
    181
    24
    Switzerland
    It just sounds like the 12V source used is switched on from time to time to check temperature of the battery pack. The only good 12V source for DRL at the front of the car is a wire at pump at the washer bottle. It carries 12V when IGN is on. It stays on if you switch the ign off until you leave the car. Perfect for add-on DRL (i.e. real LED DRL) I used this for my car and it works great.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    The installer tapped the wrong 12V wire for the DRL assembly. As stated above, you want a 12V source that is hot only when the Prius is powered up. The Prius is a smart little beast, and it does all sorts of tests and things even when powered off - it's never really off.
    This was a faulty installation. Take it back and tell them to find a switched 12V source.
    Tom
