Gen IV Prius Prime Custom PIDs for Torque app
Discussion in 'OBDII Android App' started by Cave Arnold, Jan 30, 2017.
  1. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    Is it possible to get the transmission temperature and TPMS psi data?
  2. randomwalk101
    532
    271
    texas
  3. martintoyota
    martintoyota Junior Member
    Seattle
    Four Touring
    If you want your diagnostics to be as thorough as possible then you should be using Torque Pro. Using the regular version of torque will give you PIDs like any other but Pro version has extra sensors that you might need in your case. And you can get it set up in Windows too if you want. That’s what I did.
  4. randomwalk101
    532
    271
    texas
    I do have torque pro
    Can you share the setting to display transmission fluid temperature and possibly individual tire pressure???
  5. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    I recently got an OBD2 adapter because I've got a soft spot for viewing data on my 2018 Prime, but neither Hybrid Assistant or Torque Pro appear to track what I really want to know: what's my kWh/mile? My commute is 100% electric, so tracking my mpg is pretty useless as a measure of how efficient I am driving.
    Has anyone figured out how to do this yet? If not, can anyone direct me to some resources explaining more about PIDs (i.e. something more high level then "this is how you make a custom PID" so I can better understand what/why/how cars are measuring and reporting these values)? I don't mind putting some work into getting something working if no one has already done this, but I know exactly nothing in this area. Any help is appreciated.
  6. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That data is already available. In fact, yesterday I was messing with it to see how much of an impact the heat-pump would have a maximum with the temperature outside at 16°F. See:
    MTN likes this.
  7. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Oh woops! Can't believe I overlooked that. Seems like I don't my Prius Prime's features as well as I should yet.
  8. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    Anyone know the PID to enable auto window roll down with fob?
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    It's rather surprising to me that even though there are apparently lots more Primes than PiP, we have the PIDs for the PiP but not the Prime. It would be fun to learn how to make them if I had the time.
  10. Tha_Ape
    271
    162
    Washington, DC
    I ended up getting a cable and techstream off Ebay. Was able to change a lot of options on the car
  11. jerrymildred
    11,517
    14,167
    Tampa, FL
    I have that. But sometimes we just want to monitor temperatures or battery conditions while driving and a laptop with tiny numbers while driving is just way too cumbersome and unsafe compared to big dials on a phone in its dash mount.
  12. ChapmanF
    19,003
    Reverse-engineering that kind of proprietary stuff is just super squinty, tedious, frustrating work. A lot of the Gen 1 PIDs were figured out by vincent1449p and I don't even want to guess how long it took. A new model more or less has to wait for somebody who has access to one, and the motivation, and the skills, and maybe is between gigs of using the skills for other better-paying purposes....
    jerrymildred and Tha_Ape like this.
  13. jerrymildred
    11,517
    14,167
    Tampa, FL
    Yeah, I figured as much. That's why I never seem to get around to it. Too many other more important things to do. ;)
  14. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    This is what I got for my Prius v/alpha/Plus.
