Gen1 Prius, make sure you have a backup ignition key!
Discussion in 'Generation 1 Prius Discussion' started by 3prongpaul, Dec 26, 2017.
  1. ronlewis
    ronlewis Active Member
    986
    196
    texas
    2001 Prius
    Not much to add to this except that when I lost all my keys, I got a mobile locksmith to come out and make some new keys. I think he charged $200, but I had to provide the labor to remove/replace the immobilizer.. My input: you better have skinny hands to get that immobilizer.
  2. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    and be willing to have your hands chewed up/bleeding by fitting them into the areas required....
    Raytheeagle and ronlewis like this.
  3. ronlewis
    986
    196
    texas
    2001 Prius
    Exactly!
  4. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    I talked to Paul a few minutes ago about getting a module and keys from him. He still has at least one and the price is very! reasonable. So then I called the guy who bought my Prius and he managed to find his lost keys. Maybe now he'll listen about getting at least one spare.
    Paul was very helpful over the phone, a true gentleman! Thanks, Paul, I guess I won't need your kit, whew!
    Raytheeagle and WHCSC like this.
  5. skunkwhisper
    skunkwhisper New Member
    fowler in
    2003 Prius
    I found on my 03 Prius ,date on door jam said made in 02 ,
    "turn key from off to ON (not start) 5 times.end with key off/lock but leave in ignition "
    would not work for my car but ending with key on at the 5 count did work first time I tried, only change I made.
    Video on utube at
  6. ronlewis
    986
    196
    texas
    2001 Prius
    Hey, on this topic, I have one working key for one of my cars and would like to get a copy plus a remote. Is that basic locksmith kinda thing - my master can program duplicates - I don't have to remove the security box inside the dash or somesuch work?
  7. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    If you have a working key you can. Here in Tucson, Ace's keyosk can duplicate the key and the transponder. I haven't had any luck trying to program a remote, tho. It's supposed to be possible, tho.
  8. ronlewis
    986
    196
    texas
    2001 Prius
    thx. I'll check out some retailers. I thought through all this a few years back when I didn't have any keys to a car - had to take that box out of the dash - but I forgot what I learned.
  9. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    3prongpaul in Denver can give you insight. As I remember you can have a key made if you can take the immobilizer out--it's located behind the speedo. I called Paul recently, he has/had an immobilizer with keys for about $150, but then the door and trunk key won't match.
  10. landspeed
    landspeed Active Member
    361
    209
    NZ
    2003 Prius
    My Japanese import NWH11 has the opposite problem; it has a transponder key, but also a plain metal key. Somehow, the immobiliser was disabled back in Japan :O
    Well mine would start if the blocks weren’t all at 2.5v!
  11. ammdb
    ammdb Active Member
    278
    112
    Indianapolis
    The "chicken dance" procedure for erasing all registered keys (except the one master key in the ignition), and procedures to register new master and valet key are in the Prius Repair Manual under Body Electrical - Hybrid Vehicle Immobiliser System.
    Green Ste likes this.
  12. Victor Siles
    Victor Siles Junior Member
    50
    Garden City
    2001 Prius
    I
    The other day I was at work and I had my Prius keys with me. My daughter needed to borrow my car and used my previous Prius keys ( It also was from a 2001 Toyota Prius I had sold years ago forgot I had those spares) She was able to use it to get into the car and started the ignition. Go figure.
    ronlewis likes this.
  13. ronlewis
    986
    196
    texas
    2001 Prius
    That doesn't seem right. I got a bag of keys. Maybe I try them out.
  14. jamesprius
    jamesprius Member
    142
    17
    San Jose, California
    2001 Prius
    I
    Is there a maximum number of master keys and subkeys you can have registered at a time?
  15. ammdb
    ammdb Active Member
    278
    112
    Indianapolis
    At least two masters and one sub key. Pretty sure more keys than this can be registered, the manual didn't mention a maximum.
  16. jamesprius
    jamesprius Member
    142
    17
    2001 Prius
    I
    kk, i guess the deletion is more for security then capacity.
