Gen2(and 3?) Prius Delta SOC for Torque (Android App)working?
Discussion in 'Gen 2 Prius Technical Discussion' started by Flying White Dutchman, Jan 16, 2012.
  1. Flying White Dutchman
    4,376
    313
    like topic title
    Delta SOC,"Delta SOC","21CF","0.01 * G","0","60","%","7E3"
    anyone got this working
    i get a response of 0,0%
    this including t he delta voltage nimh can give a impression of the Hv battery pack if its any good or going to maybe fail.
    NiMH Volt Delta,"NiMH Delta","21D0","((2.56 * M) + (0.01 * N) - 327.68) - ((2.56 * J) + (0.01 * K) - 327.68)","-3","3","Volt","7E3"
    the voltage delta works but i get 0,0 response with the delta soc
    wondering if anyone get the same or other response
  2. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    The multiplier 0.01 does not make sense, you will only get max. 2.55 %.
    I suggest try either G / 2 or G * 100 / 255.
    Vincent
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    I use the equivalent of G/2 in my program and haven't seen values other than 0. Someone thinks the value is not implemented.
  4. Flying White Dutchman
    4,376
    313
    well the toyota ondb2 reader can read delta soc so its implemented...
  5. 2009Prius
    2,705
    512
    63
    What's the range of delta SOC that you see with the Toyota scanner?
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    I have yet to look at it. How did you test the Delta SOC? I would think it would display 0 upon getting Prius into READY. You'll have to drain and recharge the HV battery to show the delta.
    I thought the normal SOC is between 40% and 80% but per the repair manual, the normal Delta SOC is 0 to 60%. I would think the max delta would be 40%.
  7. Flying White Dutchman
    4,376
    313
    http://www.autoshop101.com/forms/Hybrid03.pdf
    The normal low to high SOC deviation is 20%. If the Delta SOC exceeds this means that the HV battery ECU cannot correct or maintain the SOC difference within the acceptable range.
    so yes it needs to be seen during driving IF the prius is unable to maintain the SOC it wants
    but if the prius can handle the load and charge the battery pack within a 20%limit of the set SOC ( around 605 ) it wil not be a problem
    so i guess a hilly drive UP would set a delta SOC of more then 0,0
    http://lusciousgarage.com/blog/comments/gen_1_prius_battery_failure/
    http://priuschat.com/forums/gen-ii-...p3006-battery-levels-unusually-different.html
  8. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Ok, so it is the SOC delta between the battery blocks (pair of modules).
  9. Flying White Dutchman
    4,376
    313
    i read something else
    what i read is that during use the prius wants to have 60% SOC
    while trying to keep it there ( or what ever the prius wants maybe 55%? at any time ) it can not be off by more then 20%.
    so if the prius wants 60% and its trying but can only keep it at 45 % its stil ok ( 15% off ) but at 30% soc its above the 20% fluctuation
    but.. maybe i am wrong ;_)
  10. 2009Prius
    2,705
    512
    63
    And the answer is ... ?
  11. Flying White Dutchman
    4,376
    313
    Post 7
    58 % on the obd2 scanner
  12. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    20% Delta SOC is what I am seeing on my Gen III with ScanGauge. It does a good job of keeping it between 50 and 70% and maintaining 60% under normal conditions.
    It will drop down to about 50% with extended EV usage and pump up to about 70% with heavy regen braking.
    I live in the flat area of the coast so do not see a lot of steep hills, etc.
  13. 2009Prius
    2,705
    512
    63
    OK it looks like there is misunderstanding about what "delta SOC" means. There is the time variation of the total SOC that everyone can see on the MFD. At highway speed it usually settles near 60%. In general the Prius keeps it between 40% and 80%. But then there is the "delta SOC" which refers to the difference among the battery blocks, which is completely unrelated to the time variation of the total SOC. The battery blocks should be well balanced and the delta should be very small. If you truly have a battery that has 58% delta SOC among the blocks then the battery is dead for sure.
  14. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Yes, there does seem to be misunderstanding in terminology here. Vincent has been working on identifying new PID's with the ScanGauge. The Delta SOC I am referring to is grouped with the SOC max and min values and these follow the battery SOC shown on the MID.
    There are also different values for battery block with max and min voltages and then battery block numbers with the max and min voltages. I did not or would not associate these with SOC.
  15. Flying White Dutchman
    4,376
    313
    i dont have 58%
    at this point 0,0 :)
    but yes i DONT mean the SOC but the delta soc
