Gen2 Fender
Discussion in 'Gen 2 Prius Main Forum' started by Brian27, Aug 21, 2024.
  1. Brian27
    Brian27 New Member
    OK
    Hi all. I am needing to replace my driver side doors, driver side fender, front bumper, and hood on a 2004 base in seaside pearl (8s2).
    I was under the impression the body style was identical between 2004-2009, but in searching online for (new) fenders I noticed they have a different fender PN for 2004-2006 than they do for 2007-2009.
    Hood and Bumper Cover seem to be same for all years, and I can't find any info on the doors.
    My local yard has ~8 gen2's, and there's only one (a 2008) with rear end damage where I think I should be able to use the doors and fender.
    Does anyone know why there might be differing PN's online for the fender, and 2nd question is there any reason why the doors from the 2008 wouldn't fit my 2004?
    I avoid paying for LKQ's "guaranteed fit" when it's not warranted.
    Thank you.
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    What number were you looking for?
    67001-47060 FRONT DOOR, RH
    67002-47060 FRONT DOOR, LH
    Applicable for both 2003-2005 and 2005-2009.
    I didn't see any other numbers.
    Plastic on doors may vary.
    52,820
    2003 would be gen 1
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    The interior trim panel finish is different (2004-2005) from (2006-2009). Wiring can be different as well (SKS vs non SKS), etc.
  5. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    And 1 and 2
    05.2000 - 08.2003 NHW11
    08.2003 - 11.2005 NHW20
    11.2005 - 03.2009 restyle NHW20
  6. highmilesgarage
    highmilesgarage Active Member
    494
    184
    Kansas City
    Having replaced several fenders, the only thing different on the fender is the hole for the hybrid logo. 2004-2006 doesn't seem to have the logo while 2007-2009 has it.
    Priapet, Skiddmore and bisco like this.
  7. Brian27
    Brian27 New Member
    OK
    This is very helpful. Thank you.
