Gen2 Prius: Custom PIDs for Torque (Android App) with formulas
Discussion in 'Gen 2 Prius Technical Discussion' started by usbseawolf2000, Jun 24, 2011.
  1. 7Lowe
    7Lowe Junior Member
    28
    Riga, Latvia
    Thanks usbseawolf2000 and anyone else who contributed to this. I just bought the app and my BT reader arrived today so I'll be trying this out soon.
    I'm most interested in checking the health of the HV cells since my car is like 11 years old now.
  2. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    The Seawolf PIDs are good for the hybrid system,but I found some of the math wrong for gauges. I need the engine PIDs.
    XT1585 ?
  3. mfa-prius
    mfa-prius Old member
    299
    46
    Hansville, WA
    Good luck. I've been looking for those for years with no success. Must be a closely guarded secret.
  4. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    I have some of the generic values, rpm, temp, MAF, 02 sensors... I have a factory scan tool. I just lack the expertise in extracting the information. Maybe there is a good software engineer here that can help?
    XT1585 ?
  5. talonts
    talonts VFAQman
    468
    76
    So I finally bought Torque Pro 4.6 so I could load the custom PIDs. No luck.
    I have the USBSeawolf CSV file in /storage/external_SD/.torque/extendedpids, but when I try to "Add predefined set", Torque Pro does not display the USBSeawolf file. I can load that file into Thinkfree Viewer from its' location.
    I had to copy it into Torque Pro's internal directory to load it. Now to have fun setting up various pages of gauges.
    gdanner likes this.
  6. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    I had some trouble too, These androids suck at associating files with a program. I have a few that I have made. Let me know if I can help with anything. I barely get by with this part, but I am learning.
    XT1585 ?
    MERGED
    Where did you get the DLC 3/OBDII adapter from? Which style did you get, Bluetooth?
    XT1585 ?
    #586 tony2ltr, May 18, 2016
  7. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
  8. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    Mine came from Australia somewhere. I got a wifi one recently, it didn't work for crap. They replaced it with a Bluetooth one. I also have an old cable adapter. I have some resources that I might be able to get some help from for PIDs. I'll reach out to him and see what happens.
    XT1585 ?
  9. Integraoligist
    Integraoligist Junior Member
    46
    Hey all, I really need to know if the Torque Pro will read the 2005 Hybird codes? I had Autozone read the check engine light and nothing is coming up on their regular scanner... so instead of dropping $150 for a quick scan from the dealer thats 2 hours away... I was looking to get a bluetooth OBD2 reader with Torque Pro to tell me what the issues are.
    Thanks all!
  10. talonts
    talonts VFAQman
    468
    76
    I don't know if it will read ALL the DTCs, but even Torque Lite showed the P0A80 I was getting with my old HVbatt pack on my 06, so I'd suggest getting a BT reader and trying Torque Lite first.
  11. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    Torque pro is only $6, just get it and do your research on the ELM OBDII connectors. They have Bluetooth, wifi, and wired. BT is the least glitchy. Make sure you are getting it from a place that uses current elm327 chips and has good review. There are many clones out there that have problems. I have a bunch of custom PIDs for mine. System codes are hard to get other than generic ones. All you need is the correct addresses for things, and you can write your own formulas for gauges.
    The scan tools pep boys and the others use can actually screw up your Prius. YEP! That. The most common is the loss of linear valve calibration which will light the dash up like a Christmas tree.
    I can read almost everything form the HECU and HVB ECU with torque. I have about a dozen gauge sets I use for diagnosing different system issues, O am a bit weak with my collection of engine operation PIDs. I have amps/power, current, speed, and rotational direction, torque +- for the HV battery, mg1, mg2, inverter temps, HSystem power, fuel economy, fuel left to empty, HP calculations, 0-60 and 1/4 mile times. It can track your route, scan the whole CAN bus for PID addresses (which helps when using a predefined generic set to determine which ones your particular year and model use.
    I use it more than the techstream.
    #591 tony2ltr, May 25, 2016
    tangerino likes this.
  12. Integraoligist
    46
    Hey all,
    Can not seem to get the Regen Braking to work... all other items I tested for the HV batt. seems to work fine though. I tried it Dial Meter and Needle and Histogram but neither are showing anything. Does it just not work or is there a specific display type it should be in?
    Thanks!
  13. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    What are you describing? Screens in torque? You have no regen? Problem with abs or battery? What are the codes?
  14. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    Oh wait, you are taking about a torque gauge for the HVB? Do you want amps or volts or SOC?
  15. Zottel
    Zottel Junior Member
    Germany
    I was very interested in checking every single HV block.
    Finally i´ve had time to load the csv into the torque app, everyting works fine.
    Thanks to everybody who helped to create the file.
    tangerino and iodyb like this.
  16. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    So, as a point of interest, HVB codes usually set at delta .3V difference. It is a very crude monitoring system, which is why these have any battery troubles at all.
  17. gamma742
    gamma742 Member
    178
    73
    Luxury
    Do you think they should have allowed a larger variance?
  18. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    A smaller one. Much smaller. The variance and inability to correct it, is what causes premature failure.
  19. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    When I use BMS systems. I tune individual 3.3v cells to within
    .005 Volts. Across every 13-19 volts, that is .020-.025V or so. The variances in manufacturing, allows the Nickel batteries to get out of sync on their SOC, every cycle getting farther and farther away. The prius has no battery management, just monitoring, so there is nothing available ,except on the gen 1 cars to even do a crude equalization.
    gdanner likes this.
  20. iodyb
    iodyb Junior Member
    FR
    Hey Nice gauges! May you share the CSV file?
    Envoyé de mon RAINBOW 4G en utilisant Tapatalk
