Gen2 Prius slipping? No codes any ideas
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dillon Jeter, May 24, 2020.
  1. Dillon Jeter
    Dillon Jeter New Member
    Usa
    The car starts it drives kinda but ones you push the gas it acts like it's slipping
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    What make/model of OBD2 code reader are you using, as not all readers are hybrid compatible.
    Are there any warning lights being displayed on the dash?
    What speeds are you seeing when it slips?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Having the gas engine rev up higher than "normal" can mean that it is trying to charge a failing HV battery.
    Nothing is really "slipping" maybe.
    Meultaine likes this.
  4. Dillon Jeter
    Usa
    I'm using a snapon touch screen code reader a little bluetooth obd code reader the blue tooth displays more info the snapon can test stuff. I have lights on for 02 bank 2
  5. Dillon Jeter
    Usa
    Any speeds the car will barely get up to speed it even seams to have trouble in reverse
  6. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Sounds like you might need to find a hybrid compatible code reader. Try *all* of the parts shops for a free scan, as they all have different scanners. If the bluetooth adapter is compatible, you might try the app Dr Prius or Hybrid Assistant. Many like to use a mini-vci cable with techstream (dealer tech software), you'll need a windows device with a USB port, or emulate with https://virtualbox.org
    Signs of a HV battery failure. Please don't purchase a used/reconditioned battery unless from a known low mileage wreck.
  7. Dillon Jeter
    Usa
    I've confirmed hv battery problem block 12 &14 is there a place where I can buy new cells? A little history on the car the battery was reconditioned 2 years ago by dorman 3 cells blew up melting the thermostat wire I bought 10 used cells from eBay on a hunch that the cells were damage when I got the battery cell apart I realized 3 blown up and over half the cells were at low voltage some even at zero I bought a hobby charger to recondition some of the best cells I had all together I bought the car all the parts and the charger for 550 bucks. So far I've been babying the car around and it did fine till my girlfriend drove it I've only ever bought her sports cars so you can imagine what she did when she got in the car. I'm hoping I can find a couple of good sales to put in it while I save up for a complete rebuild of the battery. Thanks y'all
  8. bisco
    52,803
    how many miles on her?
  9. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Sounds like the extra 'modules' that you purchased were of questionable quality, do you have any left?
    Generally speaking, there are only used modules available, unless buying a whole assembly new from the dealership.
    Best to assess what you currently have by mAh, IR and load. What kind of charger do you have?
    There are a bunch of members that sell quality modules that are warrantied. Which metroplex(s) in the "Usa" are you nearest?
    Raytheeagle likes this.
  10. Dillon Jeter
    Usa
    She has 250000 mi
  11. Dillon Jeter
    Usa
    Well that may be true. I don't know some of the cell I reconditioned should never have been put back in. I was in a hurry to drive the car and now I'm paying for it
  12. bisco
    52,803
    you can try hybrid automotive, but idk if they sell them to non grid charger customers
  13. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  14. Berch1943
    Berch1943 Member
    146
    Arizona
    There’s your problem.
