Gen3 15" Alloys Weight ??
Discussion in 'Gen 3 Prius Main Forum' started by king mob, Oct 10, 2014.
  1. king mob
    king mob Junior Member
    What is the weight of the 15" alloys ??
    I see offset is 45"..
    thanks
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    weight comparison
    ce28 ecodrives
    15 inch: 10.1 lbs
    16 inch: 10.8 lbs
    Prius factory wheels - GII
    15 inch 14.3 lbs
    16 inch 15.2 lbs
    5X100 mm holes
    45 mm offset
    6jj rim size
    2004-2009 Prius
    15X6JJ: 5X100mm PCD, 45mm offset
    16X6JJ: 5X100mm PCD, 45mm offset
    15X6J: 5X100mm PCD, 45mm offset
    17X7J: 5X100mm PCD, 50mm offset
    17inch:11.0kg 24.3 lbs
    15inch: 7.4kg
  3. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    45 inch offset? :eek:
    :D ;)
    SCH-I535
