Gen3 2010 2011 Headlight bulb longevity - upgrade to HID?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 3prongpaul, Jan 28, 2014.
  1. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    3000K halogens maybe, but not the HID you have pictured. HIDs would melt the housing of the oem type foglights the poster above is installing.
    In addition, HIDs should not be installed in the reflector type oem foglights because they'll have massive glare due to the lack of a physical cutoff shield to block stray light.
  2. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    naa, it was just about the color what a 3000k bulb would have/
    xliderider likes this.
  3. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    The TSB below has been deleted from Toyotas TIS system. Maybe it didn't help?
  4. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Is this based on your specific VIN/Did you enter your VIN?
    I believe it goes away per VIN if applied…
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I can’t take credit for this @ChapmanF I believe explained that this was an Al length of wire which increased resistance and hence decreased voltage across the bulb. Less driving voltage/power means longer bulb life.
    OSRAM is getting close there are LEDs that are legal in certain countries per application BUT no H11 version sadly…
