Gen3 Engine Swap
Discussion in 'Gen 3 Prius Main Forum' started by JQ74, Aug 15, 2020.
  1. JQ74
    JQ74 New Member
    Oakland
    I have a 2010 gen 3 Prius and I am considering selling or swapping the engine myself. Any recommendation? I have had over 200K miles on it and had replaced the head gasket, but end up throwing a rod two months later. I love this car and have been learning a lot from working on it and I am thinking about swapping the engine myself. So if you believe in an economy of knowledge, I would like to hear from your experience. Thx & much gratitude.
  2. Solar Blue
    Solar Blue Member
    58
    28
    Columbia River Gorge
    #2 Solar Blue, Aug 15, 2020
    JQ74 likes this.
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Ditto to Solar Blue. A handful of people in Priuschat have done it and got it down. Trial and Error helped to eliminate what not to do and in what order to do it. I suggest you review the link posted above. Its a lot of work and you will have some codes to eliminate at the end. But the reviews of the successful completion are wonderful.
    JQ74 likes this.
  4. Mendel Leisk
    42,225
    There's also a few 4th gen into 3rd transplant done. Good video series here by @Ragingfit :
    Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v | PriusChat
    (It's a v in the above videos, but the engine bay's pretty much identical I think.)
    The approach he takes is likely safest; he retains 3rd gen intake and exhaust manifolds, EGR components. There's one wire extension needed, and some coolant plumbing rework.
    Reasons for using 4th gen:
    1. Pistons/rings improved
    2. More low miles and cheap engines available
    Ragingfit and JQ74 like this.
  5. ChapmanF
    18,927
    That thread also mentions that such a swap may not be approvable in jurisdictions that follow CARB or CARB-like emissions standards; too many design and tuning differences, such as the different type of EGR. (Taking it from after the catalyst, as in Gen 4, changes both its pressure and its chemical composition and effect on combustion; the engine calibration is designed for one type or the other.)
  6. Mendel Leisk
    42,225
    Yeah @Ragingfit retains third gen exhaust manifold and EGR. Still, I think if an inspector looks in a 3rd gen engine bay and sees an unfamiliar engine, he's going to be getting dour; it'll take some talking, lol.
    FWIW, if I EVER get there (which I doubt), I think I'd put in a new (3rd gen) short block and have the head rebuilt, and new gaskets/seals all-round. Doing that, wouldn't hurt to take it out in two stages: firt the head and manifolds, then the block?
    JQ74 likes this.
  7. ChapmanF
    18,927
    Right ... supplying uncatalyzed exhaust gas, through valves designed for that (so far so good), to an engine designed for catalyzed (hmm), being managed by an ECM programmed for uncatalyzed (double hmm). The inspector could be understandably skeptical.
    JQ74 and Mendel Leisk like this.
  8. Rmay635703
    Rmay635703 Senior Member
    2,684
    1,722
    Somewhere in Wisconsin
    2013 Chevy Volt
    generally In the US you are always allowed to swap in a numerically Newer engine than the failed engine . Period.
    When you smog if everything is functional you pass
    end of story.
    It would be extremely unfortunate if the ability to replace an old engine From decades Past with a new unit would become illegal.
    Many a relic from ancient times has a 350 in tow. I can guarantee there are only very bad things that would happen if you are stuck not only with OEM but with only exactly the year your car was manufactured . In fact it would be a horrific environmental disaster.
    If such an issue were pressed in a legal fashion I would fully support the individual with any necessary assistance to ensure the case thrown out.
    JQ74 likes this.
  9. ChapmanF
    18,927
    That's very generous of you. You would probably start by reviewing the CARB Engine Change Guidelines by following the link I supplied in #5.
  10. High Mileage
    High Mileage Active Member
    136
    238
    2018 Prius Prime
    JQ74, if you get serious about doing a swap I have a 2012 Gen3 engine I purchased from a wrecking yard that has 568miles on it. I purchased it when I bought my 2010. I sold the 2010 with 280K miles on it and still have the engine and trans in my shop. Its on my list to put up for sale. You are close enough that if you have interest please PM me.
    I get others swapping in the Gen4 engines into the Gen3 cars since there are many out there that are cheap and the belief is they don't have the piston rings issues that the Gen3 motors had. But if you have 200K on your existing car, I would feel pretty good this engine could last you that and longer if taken care of, and would be a quicker swap.
  11. Mendel Leisk
    42,225
    2015 for sure has revised pistons/rings, and part of the year 2014, but don't know how you could tell from the vin.
  12. Solar Blue
    Solar Blue Member
    58
    28
    My advice to the OP is to take the offer from High Milage. A gen 3 engine with only 568 miles on it? Hellz yes!
  13. orenji
    orenji Senior Member
    5,887
    3,488
    Revised piston rings does not keep from oil burning and EGR issues. GEN4 motor with retaining the GEN4 EGR is the way to go, if your gonna swap a motor.
    JQ74 likes this.
  14. Rmay635703
    2,684
    1,722
    2013 Chevy Volt
    Yes and I read that similar to requiring a red car to stay red, there are a multitude of problems with that Unfortunate logic as cars age,
    And many arguments could be made to get it thrown out, especially as cars age beyond 20 years.
    Hopefully someone has the guts to press it to the top so at a minimum an age limit for exemption is forced (not a fixed year in the past)
    As a policy Forcing as many cars into the wrecker as possible due to minor issues (like a missing cat) or forcing them into other states are both reprehensible.
  15. Mendel Leisk
    42,225
    That has proved problematic? You have 3rd gen computers trying to make sense of 4th gen EGR?
  16. ASRDogman
    ASRDogman Senior Member
    8,014
    4,071
    I tend to believe it's not so much the rings, but the valve guide seals that are causing
    the brunt of the oil burning...
    As always: result may vary!
    #16 ASRDogman, Aug 17, 2020
    Ragingfit likes this.
  17. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Toyota's TSB says otherwise. Their remedy involves replacing only the rings and pistons.
    Bad valve guide seals are a common problem on older cars when the seals become less pliable. My Gen-3 was less than 5 years old when it began burning oil.
    Ragingfit and Mendel Leisk like this.
  18. ASRDogman
    8,014
    4,071
    As I stated:
    I did NOT say the rings DID NOT cause oil burning. I said the valve guide seals
    are the bigger problem.
    There are a few people here who have replaced the valve guide seals when they
    did the head gasket. Hopefully they can provide some feed back when they have
    some miles on the engine.
    Since they didn't change the piston rings, only the valve guide seals, if oil consumption
    goes down, then there is more information about what is causing more oil burning.
    #18 ASRDogman, Aug 17, 2020
    tvpierce, JQ74 and Mendel Leisk like this.
  19. Mendel Leisk
    42,225
    @The Critic replaced valve seals when he did his head gasket. I think. He sent the head out to a machine shop.
    Maybe he'll comment.
    Raytheeagle, ASRDogman and The Critic like this.
  20. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Welcome to my world
    Rmay635703 and ASRDogman like this.
