Gen3 Inverter Coolant Temp?
Discussion in 'Gen 3 Prius Technical Discussion' started by JimN, Dec 28, 2011.
  1. Kb2lzh
    Kb2lzh Junior Member
    16
    Ca
    This is from Toshiba,
    Application Guideline #4 indicated common causes of motor failures, and it was determined that temperature kills motors. Ideally, a motor should have a relatively high insulation temperature rating, and a relatively low operating temperature for both the insulation system and bearing system. This provides for thermal margin in the event of motor overload, severe starting duty, safety margin for adjustable speed drive applications and for many other reasons indicated in ‘Application Guideline #4’. (A well-accepted rule of thumb is that for every 10°C, that the motor temperature exceeds its rated insulation temperature, the insulation life is reduced by half, likewise for every 10°C cooler, the insulation life is doubled.)
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    From the 2010 Repair Manual:
    Measurement Item/Display Range (Not operating range) :
    MG1 temperature / Min.: -40°F (-40°C), Max.: 419°F (215°C)
    While driving at an ambient temperature of 77°F (25°C): 77°F (25°C) to 212°F (100°C)
    So the 204F is within normal range. I have seen about 195F on mine with similar driving. MG1 runs about 20F hotter than MG2 in most instances that I have observed.
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,381
    67
    Yokohama, JAPAN
    It is not an operating temperature range, but it is a display range of 8 bit value.
    An 8 bit value can display between 0 to 255, and the temperature value has -40C offset, so it can display between -40C and 215C.
    On the JP service manual, the warning threshold is clearly stated as 162C (324F).
    Ken@Japan
  5. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Just to clarify, the 2010 Repair Manual also show 334.4°F (168°C) and 323.6°F (162°C) for MG1 and MG2 respectively.
    It is the same Class H motor winding as Gen 2.
    Vincent
    3 people like this.
  6. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Ken,
    Thanks for pointing that out. I should have labeled it as a display range, as it is in the Repair Manual, so it would not be mistaken for an operating range.
    The second line was the more appropriate information which listed the normal orperating range at 77F.
    Dwight
  7. ken1784
    2,943
    1,381
    67
    Yokohama, JAPAN
    On the same manual, the engine coolant temperature (THW) is also shown as Min.: -40°F (-40°C), Max.: 419°F (215°C).
    I don't think 215°C coolant temperature is acceptable.
    Ken@Japan
    2 people like this.
  8. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Ken,
    Understand. I have edited my post to indicate display range.
    Dwight
