Gen3 Reverse Beep settings/Techstream
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wjtracy, Apr 1, 2019.
  1. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Can I use Techstream to reset a Gen3 reverse beep to single beep? I gather the Gen3 reverse beep cannot be easily disabled. For a friend.
    Raytheeagle likes this.
  2. Creliandobi
    Creliandobi New Member
    South Carolina
    If you have an app like 'Dr Prius' and a Prius compliant OBD2 (dual board), you can actually very easily disable the reverse beep with a single checkbox in the app.
    Or, if you don't have an OBD2 that works with that app (or another app like TorquePro), there is a button/pedal sequence that can be followed to disable the beep entirely (sorry, can't be modified to a single beep with this sequence).
    The sequence can be found here: Disable the backup beep on a Toyota Prius
    wjtracy likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    Yes, Techstream can do that. So can Carista and a few other OBDII phone apps. But if you already have TS, that's the free way to get it done.
    Raytheeagle and wjtracy like this.
  4. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    The button sequence is Gen2, right?
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    What Techstream version do you have?
    My 10.30.028 version was able to reset mine and several other Gen3’s in the past:).
    Good luck helping others(y).
    wjtracy likes this.
  6. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...not sure version but newer for Win10
