Gen4 engine fit gen3?
Discussion in 'Gen 3 Prius Main Forum' started by Jose Reyes, Dec 18, 2018.
  1. Jose Reyes
    Jose Reyes Junior Member
    63
    Anaheim
    Im curious if anyone has looked if the gen 4 engine will fit the gen 3. The gen 3 has a tendency to burn oil and blow head gaskets.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    @cnc97 has done the swap.
    It is possible with some Frankensteining of parts(y).
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
  4. Jose Reyes
    63
    Anaheim
    Seems like it. But, I definitely think it's worth it vs rebuilding a gen 3 engine. Based from what i read the biggest issue the cooling situation and having to use the gen4 intake and airbox. I'm guessing that you also have to transfer the electronics.
  5. jerrymildred
    11,517
    14,164
    Tampa, FL
    I don't know for sure, but @cnc97 would know. Hopefully he can give you some insight when he sees this.
  6. Mendel Leisk
    42,265
    Oh have I got a movie for you:
    Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v | PriusChat
    Caveat: the vehicle getting the transplant is a Prius v, but it's equally applicable to any 3rd gen. This was @Ragingfit 's second transplant, and the first was to a regular 3rd gen Prius.
    He retains third gen intake (with throttle body) and exhaust, and EGR system. The latter basically free-spans from the intake manifold to exhaust, without connection. A nub on the side of the donor engine needs to be cut back.
    There's some modification to the engine coolant plumbing, addition of a short piece of pipe.
    Another option: transplant a 2015 engine, they are the one 3rd gen year with both revised pistons and oil rings, both with the aim of reducing oil consumption problems.
    Basic questions:
    1. What miles on yours?
    2. How's the oil consumption?
    #6 Mendel Leisk, Dec 18, 2018
  7. Prodigyplace
    12,710
    11,848
    Central Virginia
    If he keeps the 3rd Gen EGR, won't it develop the 3rd Gen issues? I thought the EGR change was what we thought fixed the Gen 4.
  8. Mendel Leisk
    42,265
    It's difficult to bring the fourth gen EGR over, would require the fourth gen exhaust system to come over as well, or a lot of cutting and welding. @Ragingfit muses a bit on the subject, shows 3rd and 4th gen exhaust mainifolds, how they differ (at the beginning of video #8).
    There might be fit issues at the intake manifold end as well, not sure. Third gen EGR is not a total disaster: periodic clean-out, say every 80~100K miles, and it's fine.
    There's many reasons for swapping in a 4th gen salvage engine. Definitely foremost: they're cheap, low mileage and plentiful. Also, it's likely Toyota's likely learned some lessons regarding oil consumption, with the piston and rings with 2010~2014 3rd gen, and carried that over to 4th gen.
    #8 Mendel Leisk, Dec 18, 2018
    Ragingfit and Bay Stater like this.
  9. zinzet
    zinzet Junior Member
    23
    Federal Way
    Hi. Does anyone know will Prius prime 2021 engine fit prius gen 3?
  10. bisco
    52,776
    if it's the same engine as the regular prius, it should, but i would wait for more experienced knowledge
  11. jerrymildred
    11,517
    14,164
    Tampa, FL
    It is the same engine as the regular Gen 4 with the exception of the sprague clutch that allows the Prime to get up to 84 mph in EV. That would have to be changed out for the regular damper clutch.
    bisco and zinzet like this.
  12. Mendel Leisk
    42,265
    I'm fuzzy, but does the damper need swapping anyway, you need to transfer over (or get another, if it's damaged) a gen 3 damper? @Ragingfit ?
    jerrymildred likes this.
  13. jerrymildred
    11,517
    14,164
    Tampa, FL
    Good question. I think I read about it, too, but can't remember any details.
  14. Mendel Leisk
    42,265
    In one of the last videos on the series @Ragingfit goes into detail about the damper.
  15. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
    You must put the damper that goes with the car on the engine.
  16. HelloMcFly
    HelloMcFly Member
    35
    42
    Oklahoma City
    I just performed this swap. It was a lot more modifying then I originally thought. Not recommended for the DIY’r
  17. techguy802
    techguy802 Junior Member
    25
    VT
    2018 Prius Prime
    I did it on mine. I kept the 3rd gen intake, airbox, egr, oil dipstick tube etc. Basically followed Ragingfit's guide. The worst part was modifying the metal lower radiator hose pipe to be shorter. There were also some rigid metal coolant pipes that came still attached to the gen 4 engine that completely threw me off on the coolant hose routing before I removed them.
  18. zinzet
    23
    Federal Way
    Hi. Finally installed 2021 prius prime gas engine into 2013 prius. Already made 3000 miles (including 2 trips 750 miles/day each) and the car runs perfect.
    Things were kept:
    1. Intake
    2. Exhaust manifold (had to bent egr cooler pipe)
    3. Some coolant hoses
    4. Damper
    New parts from prius prime 2021:
    1. Engine
    2. Egr valve
    3. Egr cooler
    4. Some coolant hoses
    Custom parts:
    1. Coolant tee
    2. Handmade metal gasket between intake and egr valve, to lower down the output hole of the gen 4 egr valve pipe.
  19. Mendel Leisk
    42,265
    Interesting: post gasket hole ID? And update how it goes. Thanks.
