Gen4 vs Gen3 - a detailed comparison of tested measured parameters
Discussion in 'Gen 4 Prius Main Forum' started by pakitt, Apr 8, 2016.
  1. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    I have data from the Gen4 test made from Auto Motor und Sport in March 2016 (AMS) and expanded the table gently created by bwilson4web below. From what I gather from the pics, they tested the car at 4C/39F, with Toyo NanoEnergy 215/45 R 17 W tires:
    Parameter Unit of measure Gen3 Gen4 Delta Gen4 vs Gen3 AMS Test values
    1 Weight of tested vehicle Kg 1534 1531 -3 1413
    2 Max speed Km/h 181.536 188.203 6.667 N/A
    3 Odometer error at 130km/h % 4.5 4.2 -0.3 4
    4 Fuel consumption at 90km/hi (56 mph) Km/L (MPG) 26.8 (62.98) 24.9 (58.515) -1.9 N/A
    5 Fuel consumption at 100km/h (62 mph) Km/L (MPG) 23.4 (54.99) 22.4 (52.64) -1 N/A
    6 Fuel consumption at 130km/h (81 mph) Km/L (MPG) 15.4 (36.19) 15.4 (36.19) 0 N/A
    7 Fuel consumption at 150km/h (93 mph) Km/L (MPG) 11.7 (27.495) 11.9 (27.965) 0.2 N/A
    8 Resistance at 100km/h KW 12.9 14.3 1.4 N/A
    9 Efficiency at 100km/h % 34.5 35.7 1.2 N/A
    10 Average fuel consumption in city Km/L (Km driven) 29.4 (1324) 26.6 (1142) -2.8 (-182) N/A
    11 Average fuel consumption in sub-urban Km/L (Km driven) 21.3 (957) 20.1 (865) -1.2 (-92) N/A
    12 Average fuel consumption in highway (max speed limit 130km/h) Km/L (Km driven) 13.7 (616) 16.4 (881) +2.7 (+265) N/A
    13 Calculated average Km/L (Km driven) 21.9 (985) 20.5 (881) -1.4 (-104) 19 6(unknown)
    14 Official Toyota Declared Combined Average Km/L (Km driven) 25.0 (985) 30.3 (1303) +5.3 (+318) N/A
    15 MFD error % 6.4 5.8 -0.6 N/A
    16 Acceleration 0-40 km/h Seconds N/A N/A N/A 3.0
    17 Acceleration 0-60 km/h Seconds 5 4.9 -0.1 N/A
    18 Acceleration 0-80 km/h Seconds N/A N/A N/A 8.1
    19 Acceleration 0-100 km/h Seconds 11.3 11.1 -0.2 11.8
    20 Acceleration 0-130 km/h Seconds 18.9 18.6 -0.3 19.6
    21 Acceleration 0-160 km/h Seconds 30.6 31.4 0.8 32.5
    22 400m Sprint Seconds 18 17.8 -0.2 18.2
    23 400m Sprint exit speed Km/h 127 127.5 0.5 125
    24 1km Sprint Seconds 32.6 32.5 -0.1 N/A
    25 1km Sprint exit speed Km/h 164.1 161.8 -2.3 N/A
    26 Pickup 60-100km/h Seconds N/A N/A N/A 6.6
    27 Pickup 70-100km/h (min/max load) Seconds 5.8/6.4 6.4/6.7 +0.6/+0.3 N/A
    28 Pickup 70-120km/h (min/max load) Seconds 10.6/11.8 11.5/12.1 +0.9/+0.3 N/A
    29 Pickup 80-120km/h Seconds N/A N/A N/A 8.5
    30 Pickup 70-140km/h (min/max load) Seconds 16.8/18.9 18.4/19.7 +1.6/+0.8 N/A
    31 1km starting from 70km/h Seconds 28.3 29 0.7 N/A
    32 1km starting from 70km/h exit speed Km/h 166.1 159.4 -6.7 N/A
    33 Breaking distance at 100km/h (cold start) Meters (g) 46.4 (0.85) 42.5 (0.93) -3.9 (+0.08) 38.1 (N/A)
    34 Breaking distance at 130km/h (cold start) Meters (g) 76.6 (0.87) 71.0 (0.94) -5.6 (+0.07) 65 (N/A)
    35 Breaking distance at 100km/h (half dry tarmac + half cobbles) Meters (g) 52.2 (0.75) 48.7 (0.81) -3.5 (+0.06) N/A
    36 Breaking distance at 100km/h (wet tarmac + simulated ice) Meters (g) 113.8 (0.35) 119.7 (0.33) +5.9 (-0.02) N/A
    37 Noise at 130km/h dB(A) 71.4 66 -5.4 71
    38 Noise at 50km/h (cobbles) dB(A) 77.1 72 2 -4.9 N/A
    39 Noise at 50km/h (tarmac) dB(A) 60.8 54.7 -6.1 N/A
    40 Noise @ Max speed during acceleration dB(A) 73.7 73.6 -0.1 74
    Interestingly enough the German magazine has a lighter vehicle and they don't measure "scientifically" fuel consumption at constant speeds. It's like as if that is not really important. They report more on speeds, braking distances, and the such - i.e. more the "dynamics".
    telmo744, Sergiospl and Mendel Leisk like this.
  2. bwilson4web
    16,204
    1 Calculated average Km/L (Km driven) 21.9 (985) 20.5 (881) -1.4 (-104) 19.6(unknown)
    2 Noise at 50km/h (cobbles) dB(A) 77.1 72.2 -4.9 N/A
    Suggested changes, not sure about first data row. The second looks right.
  3. Alesf76
    Alesf76 Member
    89
    33
    Italy
    Forget quattroruote mileage test result. They do their test on the Vairano track, which is good to test a sport car, not to simulate everyday driving.
    Look yourself at the track map
    https://upload.wikimedia.org/wikipedia/commons/9/98/%22_15_-_ITALY_-_Circuito_di_Vairano_Test_Track_03_FULL.jpg
    For example to test highway mileage they have only a couple of km of straight track, so they accelerate full throttle to 130 km/h, draining the battery, then measure the consumption for the next kilometer, with the engine also charging the battery to recover the SOC loss, then stop because they can't drive at that speed in those curves. End of the test...
    bwilson4web likes this.
  4. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    I agree, their preoccupation with "acceleration dynamics" is striking, especially for a vehicle like the Prius whose emphasis is on "fuel economy dynamics".
    It also seems off to me that on almost every fuel economy metric they tested they found the Gen 3 a bit better than the Gen 4, if I read the data correctly??
    My experience is the opposite: for the same runs I do consistently better in the Gen 4 than I did in the Gen 3. Perhaps steady speed fuel economy numbers are only part of the story? After all, the Prius' operation is a mosaic of ICE-ON and EV, so that there is an advantage to being able to spend more time in EV?
    For example. last night I had to drive from JFK airport in New York to my home in Connecticut. Over the >110 mile/177km trip my Gen 4 averaged 76-77 MPG on the MFD, so probably actually 75-ish. I drove mostly 50-55mph (speed limits are 40-55mph and increase to 65mph for only the last 20 miles or so). I would have been hard pressed to manage that in the Gen 3, especially at that cool temp (54F/12C).
    #24 JohnF, Apr 24, 2016
  5. bwilson4web
    16,204
    Ok, so if the Gen-4 supports a greater depth of discharge than the Gen-3, during acceleration, it would drawn down the traction battery energy deeper than the Gen-3. Then during the constant speed section, the engine would be at a higher power setting replacing the charge. This could be a characteristic difference between NiMH and LiON battery management.
  6. pakitt
    2,173
    1,313
    Colorado
    I think I will have to post then my Gen3 to my Gen4 fuel values once I have my Gen4 (when??) in my hands :)
    I have so many routes, and temps and fuel consumption values saved, it will be real fun to see how the Gen4 really performs in similar or same conditions.
    Because it seems from what I read in magazines, and comments, that we here in the forum have a more scientific approach than those who should really have it.... ;)
    I mean, both magazines don't mention ambient temperature - and we all know how the Prius performance in fuel consumption changes quite drastically when the temp reaches a certain "magic" value.
    And I have never seen a Gen 3 vs Gen4 comparison from any US or other non IT/DE magazine online/offline - has anybody seen any real testing done in a scientific way from any of these media sources?
    I can only find tens of video reviews all saying the same things one finds in the Toyota Press releases, and some very personal impressions about plastics, questionable usage patterns and who should buy the car or not, etc. which most of the times makes me raise an eyebrow...
    #26 pakitt, Apr 25, 2016
    Tideland Prius and bwilson4web like this.
  7. Mendel Leisk
    41,413
    I think ventilation settings: target temp, AC on or not, they can make a difference too.
    Tideland Prius and pakitt like this.
  8. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    I may be wrong but I don't think the European market is getting the lithium battery packs, just nigh
  9. pakitt
    2,173
    1,313
    Colorado
    We are not, only NiMH
