Gen5 prime/phev battery temp management
Discussion in 'Gen 5 Prius Technical Discussion' started by Templeton, Jun 19, 2025.
  1. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    The car's not checking anything itself about 3 or 1 phase mains wiring - the EVSE reports what's available. The portable EVSE knows it's for a normal mains socket, so reports suitable limits. And is always 1-phase. A fixed EVSE reports according to its installation.
    The portable EVSE limit differs in different countries. UK might be 10A, some are lower. Different leads are supplied per country.
    Finland is 8A continuous, or 12A for 2 hours - I've got a 3rd party charger that supports 12A for the first two hours as fast mode that I keep in the car. The Toyota one was just 8A, and that stays in use at home.
    That charger will do 2 hours at 15A in some countries. Seems brave.
    #21 KMO, Jun 22, 2025
    Quovadis007 likes this.
  2. Trollbait
    12,806
    Or the code uses thicker wires,
  3. Quovadis007
    Quovadis007 Junior Member
    25
    COVENTRY
    2024 Prius Prime
    Business Ed. Plus
    In the UK, Belgium and the Netherlands (family) you charge an Ev /Phev at a normal house at 10A and 220 / 240 volts and always 1 phase. In the other countries I have no family or I have not been on holiday with the Prius 5 yet. :)
  4. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    Checking again, that DEFA charger actually defaults to 16A standard continuous for the Netherlands, with 10A as the "slow" mode. Yowzers.
    Wouldn't need a dedicated charging port for the Prius, if your standard mains socket doesn't melt.
    So apparently no regulatory distinction between short-term and long-term power there?
    UK they do as 10A continuous, 13A for 2 hours, or 8A low.
