Generation 1 Tire Advice
Discussion in 'Generation 1 Prius Discussion' started by beth524, May 25, 2012.
  1. beth524
    beth524 Junior Member
    66
    Ithaca, NY
    2001 Prius
    I am having difficulty finding a thread on tire recommendations for my 2002. I will be on my 4th set of tires (85000 miles) and want to replace them with something different than the OEMs. I see that it is possible to use 185/65/14 rather than the original 175/65/14, but is there already a discussion concerning which tires are best? Thanks!
  2. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    There are only about 100 tire threads on here and I think I read through all of them.
    I just got a set of Michelin Defenders on mine a couple of days ago. I used TireRack.com and had a local place put them on for me. Too early to review them.
  3. youngnbald
    youngnbald Junior Member
    66
    Bloomington, Illinois
    2001 Prius
    I
  4. theSaj
    theSaj Junior Member
    25
    Pennsylvania
    2002 Prius
    Having gone through a few different tires, we had EXCELLENT luck with Michelin Hydroedge. I felt that the vehicles handling greatly improved. We did lose about a 1-2 MPG.
    But we got 70,000 miles out of our first pair of Michelins. Granted, they were rated for 90,000. But Costco gave us about $20/tire discount on our next purchases. Which I think were GoodYears. These only lasted about 35,000 miles. So the next set of tires we went back to Michelin Hydroedge.
  5. MSAGRO
    MSAGRO 2010 Prius Five with Advanced Technology Package
    259
    227
    Portland Oregon
    ^ what size were your hydro edges? 175 or 185?
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    In the OEM size I would get the Michelin Defender. We don't know a lot about the mpg it provides but even if it is 1-2mpg worse than OEM the crazy high tread wear warranty should make this tire one of the lowest cost/mile to. The current champ is the Michelin Energy Saver A/S and following closely is the YOkohama AVID Ascend. I would chose any of these over the Hydroedge.
  7. MSAGRO
    259
    227
    Portland Oregon
    Thanks, my brother has the Michelin Energy Savers on his 2005 Prius. Would they be just as good on a 2002?
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    They don't make them in your size unfortunately.
  9. MSAGRO
    259
    227
    Portland Oregon
    What would you recommend for the Gen1 then? I want long tread life vs. MPG
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    See post #6 :)
  11. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    I have not seen a drop off in MPG with the Defenders, but I have done other things to the car so I can't say if all will have similar results.
  12. beth524
    66
    Ithaca, NY
    2001 Prius
    Thanks for the suggestions. I am going with the Defenders.
  13. beth524
    66
    Ithaca, NY
    2001 Prius
    Just one more question--on the Michelin website, it states that the Defender in the 175/65/14 has a max load @44psi of 1047. Wouldn't this be unsafe, as John's link says to be sure it can support 1102lbs.
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Personally I think it is fine. 90% of the replacement tires on the market are 82 or lower.
  15. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    I've had no issues.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I also noticed this at TireRack.com when you search for 2001 Prius.
    Important Notes:
    Tread patterns must often be tuned to accommodate different tire widths. While tires shipped will match your order's specifications, photos used only represent typical sizes.
    Vehicle comes OE with XL tires. SL will work at mfg. suggested pressure levels (35psi Front, 33psi Rear).
  17. PeterHaas
    PeterHaas Member
    152
    29
    Monterey Bay, CA
    My 2001 Gen 1 came with a brand new set of "Primewell" (Indonesian ?) 82S tires.
    I bought a used alloy wheel on eBay and a fifth Primewell tire at one of the "usual suspects" retailers and had it mounted and balanced and then installed as the right rear tire (Primewells are uni-directional), and inflated to 42/40. The original right rear tire thereby became my full-size spare.
    The set is doing well, but I intentionally restrict this car to in-county driving; for out-of-county driving, which includes a mountain pass and two difficult climbs/descents, I use my 2012 gen 3.
  18. ChapmanF
    18,951
    Four years late to respond to that post, but for future readers' reference: you can see the relevant specifications and the math gone through here.
    TL;DR is there are two different safety standards you can try to meet, one the us Federal Motor Vehicle Safety Standard, or a more stringent one from the Tire and Rim Association, and you won't meet the stricter TRA standard (but neither do the tires Toyota originally sold on the car), but you do meet the FMVSS (as did the original tires, of course). It's possible Toyota spec'd XL tires for reasons other than load capacity, such as sidewall stiffness.
    It also matters whether your tire size has a letter P in front or not. The differences between P-metric and Euro-metric ratings are not just different numbers, but entirely different schemes for what the numbers mean, as also explained in that linked post and following.
    -Chap
  19. PeterHaas
    PeterHaas Member
    152
    29
    Monterey Bay, CA
    The complete description of my tires (all five) is:
    PRIME WELL PS830 175/65 R14 82S
