Generation 2 heating not working
Discussion in 'Gen 2 Prius Main Forum' started by Ghalib bhinder, Mar 1, 2018.
  1. Ghalib bhinder
    Ghalib bhinder New Member
    Birmingham
    Hy can any 1 please help
    I changed my prius 2005 water pump and belt and after that heating not working
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Some questions:
    • Is the system completely bled of air, including the thermos?
    • Does the heater turn on?
    Keep us posted (y).
  3. Ghalib bhinder
    Birmingham
    Thanks for response
    I did but not like 20 minutes it'
    About 10 minutes and I opened just lead because the top bleeder are slipped and it was not opening
    And you now after the problem sign shown in the dashboard and when car went to maintenance mode and engine is keep running about and I add more coolent in after sometime main radiator fan automatic on and car throughing water out with bubbels I jump back into car in dashbord mentinence light was still on is it goes off automatic or not.and then i put engine off and start again and start driving
  4. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    You probably still have more air in the system. Keep checking the radiator cap ;).
    Good luck and keep us posted (y).
  5. padroo
    padroo Senior Member
    2,763
    2,253
    You did fill it up at the radiator cap and not the overflow tank didn't you?
    It took me three hours to get the air out of my Gen 2.
  6. Ghalib bhinder
    Birmingham
    Ok I try and let you know many thanks
    1 more thing before change the pump coolent level goes down while it's happen only when driving not in stratinory
  7. Ghalib bhinder
    Birmingham
    Its due to pump faulty or something else wrong
  8. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Was there coolant residue above or below the pump? Usually when the bearing fail on the pump coolant begins to leech out of the seal around the shaft and bearings which then puts coolant below the pump and on the underside of the hood as the pump is moving and it gets thrown upward.
    Hope that helps(y).
  9. Ghalib bhinder
    Birmingham
    I put both side radiator and in overflow aswell today I left the both leads open start the engine and I was adding more water I put about 15 litter water and still taking more even I changed termostate today aswell don't know what happen heating still not working
  10. padroo
    2,763
    2,253
    The system doesn't hold near that much water, where is it all going?
