GenII HV Battery Fan cleaning and testing
Discussion in 'Gen 2 Prius Technical Discussion' started by w2co, Jul 30, 2019.
  1. bisco
    52,837
    and get a scanner to watch battery temps
    WilDavis and w2co like this.
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Techstream will tell you if there is even a call for the fan and what speed it should be running at.
    strawbrad, w2co and SFO like this.
  3. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Yup I already got a few pics, but it wouldn't allow me to post them...Must have an external site to post from. I got a Box account, would that work? And we got Auto Enginuity with the Toyota module installed so we're ready to go on that.
  4. richmke
    richmke Member
    73
    48
    Milwaukee, WI
    dorman 601-029 about $200
  5. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Does the scangauge have a battery temp parameter? I know it has BTV and BTA what about BTT..
  6. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Lets see if this works.. here's the dead blower.
  7. w2co
    w2co Member
    366
    81
    Longmont, CO.
    #27 w2co, Jul 31, 2019
  8. w2co
    w2co Member
    366
    81
    Longmont, CO.
    This is with blower and air input duct to battery removed. Notice the slot shaped hole for battery air inlet.
    #28 w2co, Jul 31, 2019
  9. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Here's Auto Enginuity dongle and win xp pro machine with AE Installed and ready to go.. DSCF1210.JPG
  10. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Here's the fans I will temporarily use. Came ffrom an mri transmit pwr supply, they both blow a LOT of air! Notice the hot glue sealing the box edges.. DSCF1211.JPG
    #30 w2co, Jul 31, 2019
  11. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Notice the shape which will match the top of battery case slot. The fans will already be slanted downward into the slot.
    #31 w2co, Jul 31, 2019
  12. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Get the shape correct.
  13. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Almost there.
    donbright likes this.
  14. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Who said a prius can't be fixed with duct tape?
    Data Daedalus and donbright like this.
  15. w2co
    w2co Member
    366
    81
    Longmont, CO.
    The final product! Ready for testing Tomorrow morning. Notice I connected the fan wires to original 12v cable conn. Make sure polarity is correct! Used more hot glue on the box cracks to seal it up. Got to take wife to work at 7AM. It should work better than nothing which is what it had..
    #35 w2co, Jul 31, 2019
  16. richmke
    richmke Member
    73
    48
    Milwaukee, WI
    My guess: Close, but no Cigar. Yes, it will blow air. No, it won't blow with enough pressure. Computer Case Fans move a lot of air, but not with a lot of pressure. The Toyota Fan can move a lot of air, and blow it with a lot of pressure to push it through/past all the batteries.
    w2co likes this.
  17. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Yes you are correct richmke, but today I noticed it still never comes on. So there is another problem with the 12v line to the fan, probably caused by the original blower drawing way too much current! I measured it on the bench at 5A continuous, and has maybe 10A spike when first starting. And yes when running it does blow a LOT of air at high pressure. So this little experiment showed that there's another problem is all.. On another note, I noticed here in the Denver metro area there's a place selling reconditioned packs for $700. That would be good for another 3-5 years of life for this 06' with no other problems when this 13 yr old pack finally dies...
  18. bisco
    52,837
    you haven't read the reconditioned pack threads yet?
    Skibob, WilDavis and SFO like this.
  19. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Nope, just getting back here after a longtime...what about the reconditioned packs? Let me guess - they last maybe 2 years if you're lucky because they have already used modules that were mixed and matched...
  20. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Hmmm.. Electron Automotive rebuild kit looks promising for when this battery dies..Have you heard anything about them? In the kit you get all new modules and new buss bars which are already conditioned. Easy enough.
