GenIII Prius Custom PIDs for Torque app
Discussion in 'OBDII Android App' started by usbseawolf2000, Oct 7, 2011.
  1. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    Why are there no PIDs in the spreadsheet for HVB amps, volts or temp? I'm surprised that those are not in the spreadsheet. Those are 3 PIDs that I would like to track. I converted the SGII XGauge codes that I use for those 3 parameters to Torque PIDs. After I verify that they work in Torque I will post them here so that others can use them too.
  2. djasonw
    djasonw Active Member
    961
    123
    Coconut Creek, FL
    Thanks! I'll try it later on. Hard to believe the wealth of information you get from an inexpensive adapter and five bucks!!
    XT1053 ?
  3. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    How can I calculate HP like what the ScanGauge reads? The Torque built in HP at wheels & Torque at wheels don't work. They don't provide data all the time that the ICE is on. The HP in the SGII is the HP being produced by the ICE only which is what I want to use. I could only find info about getting this data for the Gen II Prius in that thread.
  4. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    You have custom PID "actual engine torque" and multiply it with revs
  5. superkikin2
    superkikin2 New Member
    hello everybody
    I need a data extracted from ODB2 but can't find it anywhere how.
    I need a PID for actual trip distance read from one of the wheels, not from GPS. Exists a wheel speed PID, so I guess the distance data must be known for the car.
    Thank you very much.
  6. crabbyman
    crabbyman Member
    79
    30
    Get this to work? Someone wants me to test HV amps for them.
  7. neez
    neez Member
    194
    37
    Thanks, i had to add the extendedpids folder, and mine isn't installed on the SDcard, it installed onto my phones main HD.
    gamma742 likes this.
  8. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi hybridbear and crabbyman,
    I've used different names in my spreadsheet because I want to follow the names used in Techstream.
    HVB amps => Power Resource IB (row 270)
    HVB volts => Power Resource VB (row 264)
    HVB temps => Temp of Batt TB1, TB2 & TB3 (row 267 ~ 269)
    The row numbers may change if I have updates, so pls search by keywords.
    Vincent
    hybridbear likes this.
  9. crabbyman
    crabbyman Member
    79
    30
    Found it after I posted, I apologize. Too many threads comingling. Thanks!
  10. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    Thanks Vincent! I'll get those PIDs added to Torque in the next couple days.
  11. Markee
    Markee Member
    334
    South Florida Broward County
    I was able to follow the below directions and shut down seat-belt and reverse beeping but I'm still getting this continual blinking seatbelt light is there a way to stop that light also ?
  12. Akito teriyaki
    Akito teriyaki Junior Member
    San jose
    Guys I tried Tachyon tool for Toyota Hybrids on my Gen III Prius from Japan.
    It works for me and provide Battery and MG data + many more.
  13. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    Does it work with other than Tachyon OBD bluetooth adapter?
  14. Akito teriyaki
    San jose
    As I know the software and the hardware linked together, so need to have the hardware + Software.
  15. Akito teriyaki
    San jose
  16. yothere
    yothere Junior Member
    22
    Hello friends, thank you everyone who put their time into making the custom pids for Torque. I recently Torque and an obd2 bluetooth scanner. I have a few questions.
    - Is there a gauge to measure fuel flow or GPH? There's a "Fuel Flow" gauge but it just reads " -- " and a few others that also don't display.
    - What does "SOC (all)" measure? The "SOC" gauge is clearly what it says it is, but "SOC (all)" usually just hovers at about 58% regardless of what "SOC" is.
    - What is the difference between "Volts (CM)" and "Volts (ad)" ? CM is usually about 14.7 and ad is about 13.8.
    - Scangauge has a few gauges I don't see here. Has anyone converted them? The ones I'm looking at are A/C power usage in watts; Friction Brake sensor; and Regen operating force.
    Thank you!!!
  17. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    looking to try this too.
  18. yothere
    22
    Anyone? How do you get the GPH gauge? Thank you!
  19. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    I am trying to download the csv file for the gen2 PIDs but the link in the first post and post #22 do not work returning a file 404 error. Can a working link or a fresh copy for the gen2 be posted? Thanks .
    John (Britprius)
  20. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The server upgrade must have messed up the url. I fixed it.
    Gen2 thread is here: Gen2 Prius: Custom PIDs for Torque (Android App) with formulas | PriusChat
