GenIII Prius Custom PIDs for Torque app
Discussion in 'OBDII Android App' started by usbseawolf2000, Oct 7, 2011.
  1. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Sorry to bother you. It is 8 years after your post. I also drive a 7 seater prius. Could you share how do you setup hybrid battery monitoring in Torque pro. It has 8 blades therefore setting should be different.
    #401 Ohid, Aug 2, 2021
  2. PickleMint
    PickleMint Junior Member
    The Netherlands
    For monitoring the battery i would suggest the 'Dr. Prius' app. Another nice app is 'Car Scanner ELM'. This can read the battery but also a lot of other sensors.
  3. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Car Scanner ELM only monitor total pack voltage. No details of blade voltage and internal resistance.
  4. PickleMint
    The Netherlands
    Maybe you don't have the correct vehicle profile selected then? I can read the voltage of 14 different modules just like the Dr. Prius app.
  5. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Please advice me how to select correct vehicle profile. Mine is Prius Alpha/Plus with Li-ion. It has 8 blades.
    Could you post your car monitoring photo or video?
  6. PickleMint
    The Netherlands
    Have you tried selecting 'Prius Gen.3 2010+' in Car Scanner? This works for my Auris (European car) as it has the same engine/hybrid system as the Prius 3.
    Then after connecting, go to 'All sensors' and scroll down the list to see if you have sensors like 'Battery Block Voltage -V09' etc. If you see them, you can then create custom dashboards by going to the 'Dasbhoard' option.
    Did you also try Dr. Prius?
    #406 PickleMint, Aug 3, 2021
    Ohid likes this.
  7. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Thanks I will try but there is more Battery blocks. I need 1-8 blocks. Should I delete Battery Block Voltage -V09 to V14?
    #407 Ohid, Aug 3, 2021
  8. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    I am planning to adopt Prius 3rd gen PIDs to my Prius Alpha 2015 Li-ion Battery. Since Prius Alpha and Prius Plus also considered as Prius 3rd gen but they have Li-ion instead of Nimh. Moreover, Alpha or Prius plus has less Battery blocks than Nimh. They have 8 blocks but Prius 3rd Gen has 14 blocks Nimh battery.
    So if I delete PIDs for Battery Blocks Voltage-V09 to V14. As well as Internal Resistance 09 to 14.
    What will be the consequences? Does it give me correct readings of my Li-ion pack?
  9. Sarsa Parilla
    Sarsa Parilla New Member
    San Jose, CA
    Sorry if this post is out of place. But I'm a software developer, I'm looking to develop an app to thwart catalytic converter theft, having been a victim of one. My first research is into how to trigger the panic alarm programmatically, and I'm hoping a few pointers here and there will help me along. I don't see anything in the PID list in this thread, do you think it is possible at all, or would I need to do some reverse engineering by triggering the alarm with the keychain and capturing the code?
  10. Sterlingarcher6969
    Sterlingarcher6969 Junior Member
    64
    22
    Bit late
    But check out autopi
  11. KostyaSha
    KostyaSha Junior Member
    Belarus
    i'm looking for engine (note available lists mention only inverter) water pump parameters. How do you get all this formulas for PID values? Is it possible to get them somehow from TIS files?
    rjparker likes this.
