GenIII Prius Custom PIDs for Torque app
Discussion in 'OBDII Android App' started by usbseawolf2000, Oct 7, 2011.
  1. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    Re: PIDs/Sec
    Andy, thanks for the reply and welcome on Priuschat. I really like your design. I find some China OBD-II small case manufacturer and I'll contact them after their New year holiday, when all country is paralysed. I think the demand for OBD plugs will increase following the Android Torque (or similar/better) based market.
  2. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Re: PIDs/Sec
    Update 2: I've created a Google spreadsheet, do feedback if there are any PID(s) not working or incorrect. Those highlighted in green are not tested yet.
    Thanks to usbseawolf2000, Adrian Black, jdcollins5, Paja, motoleon, frenchie, lennonqpublic and many others who had helped to make this list possible.:)
    Vincent
    Pakeha_Prius likes this.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    I added the link to the first post.
  4. Cactus Hybrid
    Cactus Hybrid Member
    129
    46
    Paradise Valley, Arizona
    Great work...Do you need a Beta tester for the 2012 Prius v? I just bought the KIWI and Torque..
  5. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    Surely you can. just download the current Custom PIDs, copy csv file to Android device. Just be aware there is huge number of PIDs.
    I'm using HV Battery current flow, Coolant temp, SoC, ICE Revs, Room temp (looks to be higher then reality, but inline with techstream reading) and MG1, MG2 temps. I'm attaching my current Torque file (credits to Vincent).
  6. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I posted it in Prius v Technical section. No reply so far. If you have any feedback/test results, that will be the best place.
  7. priusito_de_mi_vida
    priusito_de_mi_vida Junior Member
    78
    Spain
    I have trying some pids these days, founding several ones that didn't show accurate readings. Specially, those ones related to temperature ºC.
    In the following pic, all the gauges seem to be ok.
    - SOC gauge matches with my scangauge one.
    - AMP battery current also matches with my scangauge reading.
    The delta SOC gauge always shows 0.0%. I think that is the usual...isn't it?
    In the following pic i found bad readings:
    - All the inverter temperatures ICF, I1C, I2C are wrong, showing higher values than real. In fact, the values are closer to ºF than ºC.
    - ExF, RmC, ETF, show always erratic, bad readings.
    Ok gauges are:
    - M1C, M2C, the MG's temperatures. Both matching with my scangauge ones.
    Coolant and intake are ok and they are gauges included with torque. Air temp, HP and Oil temp don't work properly.
  8. vincent1449p
    894
    332
    Singapore
    Yes, it is normal as confirmed by TS.
    I think you 're still using the beta ver. I gave you, the errors were corrected in the ver. dated 31Jan12.
    Air temp can use the new ExF.
    HP need to configure Torque settings, can't help with that, sorry.
    Oil temp not applicable in Gen3.
    Vincent
  9. priusito_de_mi_vida
    78
    Spain
    Hello again. I changed the csv file and now ICF, I1c and I2c are showing the right data.
    Air temp, RmC and ExF are still showing wrong, erratic values:
    I'll keep cheking on them.
    Regards.
  10. inof
    inof New Member
    France
    I would like to give my feed back with My Auris HSD.
    Auris has same system as Prius Gen III.
    I've bought a low cost odbc II ELM from Amazon and Install torque. I downloaded the csv file ( first page) and It works very good. The Battery pack is very useful to see if we recharge or consume. I cannot post some photo yet .
  11. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    It is great to see it also work with Auris HSD, as expected.
    After a few more posts, you should be able to pics. Which Android device are you using?
  12. inof
    inof New Member
    France
    I use my phone. It is a Simvalley sp 80. slow but enough for torque software.
  13. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    RmC shows higher value, but in line with Techstream reading. The value from the sensor is not absolute one (by my opinion there is some offset but it is not linear, maybe it a reason why car doesn't present it).
    ExF shows the same reading as displayed on the A/C panel.
  14. priusito_de_mi_vida
    78
    Spain
    I will check ExF again.
    The problem is not only about higher values, they are erratic too: -2, 20, 30, 0...making no sense.
  15. priusito_de_mi_vida
    78
    Spain
    I have a new gauge that doesn't work:
    It is the "engine run time" one.
    I suppose that it should show the time that ICE is on, but it always shows the reading "0":
    Is there something wrong with this one?
  16. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    It is not one of the custom PIDs. You can report it on Torque Forum.
  17. priusito_de_mi_vida
    78
    Spain
    Yes it is. Is the gauge in the 13th row on the spreadsheet
    I think it has to be a gauge for our prius because in a normal car ICE is running all the time (except those with start&stop, off course).
  18. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    My bad. Anyone with SGII and Gen III Prius confirm that it works?
  19. vincent1449p
    894
    332
    Singapore
    According to the Repair Manual, engine run time is the elapsed time after starting engine. From TS, this time continues counting even if engine is stopped. So I believe it starts counting once you are in IGN-ON or READY, need someone to verify.
    Other than the ECM, the HV CPU also has this information. Could you try this PID from the HV CPU?
    Name ShortName ModeAndPID Equation Min Value Max Value Units Header
    1 Engine Run Time ERT 2101 J * 256 + K 0 65535 seconds 7E2
    Vincent
  20. priusito_de_mi_vida
    78
    Spain
    I have elm32 + scangaugeII. It doesn't work for me yet.
