Get me a bigger tank
Discussion in 'Prius c Accessories and Modifications' started by my#7, Feb 13, 2013.
  1. my#7
    my#7 New Member
    LI,NY
    OK,it`s great on gas but 9.5 gallons just aint enough.My monthly drive to Toronto(540mi. door to door)has me stopping too many times.
    Just got the car so maybe the 41mpg HWY will get better once I break 3-4000 miles(I hope).
    Would like info on how to replace gas tank to add 3~4 gallons.
  2. Hyper_PriusC
    Hyper_PriusC Member
    83
    55
    San Jose, CA
  3. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    The gas tank in the Prius C is too small. However, you can drive 540 miles with one stop. There would be a lot of work and expense in replacing or adding an additional fuel tank (consider safety as well).
  4. PriusCamper
    PriusCamper Senior Member
    13,273
    5,361
    Pacific Northwest, USA
    What kind of computer/sensor problems would you run into if you added a second tank? Seems like the way they integrate all the Prius components you'd have to do some spoofing to prevent error codes and malfunctions? Has anyone ever done this successfully?
  5. bisco
    52,595
    upgrade to a prius, i used to go 600+ miles on a regular basis in my 08.
  6. PriusCamper
    13,273
    5,361
    Did I miss something? I think we're all Prius owners here? And 600 miles to a tank is a bit of an exageration... I mean if you too often risk running out of gas and you drive exclusively between 32 and 53mph without ever stopping that might be possible, but....
    UPDATE: Oh, I guess your meant to write "Prius Plugin"
  7. bisco
    52,595
    no, they didn't make a plug in in 08. i can't detail my driving style, although i do try to get as much as i can out of it. 60 mpg average was pretty easy. i don't drive faster than the speed limit. plenty of people get this kind of mileage and better.
  8. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    How fast are you driving?
  9. my#7
    my#7 New Member
    LI,NY
    70~77mph
  10. my#7
    my#7 New Member
    LI,NY
    I also considered how this will effect the computer.Anyone know if the 9.5 tank has a baffle inside?Maybe deleting the baffle could get me a few more gallons.
  11. Mendel Leisk
    42,096
    Like maybe once, LOL?
  12. iClaudius
    iClaudius Active Member
    435
    135
    Kansas
    Prius range is about normal. You would have to do one fillup with just about any vehicle.
    That said, your mileage of 43 seems way low. I drive normally, just made a 900 mile run, in winter, over mountains, on snows, going 75 mph for long stretches with average including many stops of 69 mph with 45 mpg average.
    but even with that, you'd have to stop once as you do now.
  13. my#7
    my#7 New Member
    LI,NY
    Actually have to fill before I break into Canada since over $5/gallon up there.Then I fill again when I cross back into Buffalo and then again before I get into Long Island.My `05 E320CDI had much better range but diesel price is a scam.
  14. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Baffles normally occupy close to zero volume. There is a couple of gallons of trapped air space in the top of the tank, but that's a safety volume for fuel expansion and some other things. You shouldn't try to use that.
  15. Hyper_PriusC
    Hyper_PriusC Member
    83
    55
    San Jose, CA
    this is true. even if you sophisticate the system with liquid level sensors in the fuel cell and some automated solenoid or switch between the pumps, there will still be a snowball of problems. I would imagine besides error codes, your gas tank level indicator and your MPG gauge is no longer accurate.
    there will probably be a great amount of tech sacrifice to make this upgrade.
    PriusCamper likes this.
  16. PriusCamper
    13,273
    5,361
    Only way to take the components out of the inside of the tank is ripping it open with metal sheers, which means the tank won't hold gas anymore.You could look into installing a European version of the gas tank that has no bladder inside. But no guarantee the US computers are going to accept that more simple design. The lack of bladder components will probably light your dashboard up like a Christmas tree.
  17. Mendel Leisk
    42,096
    What did Shakespeare say? Much ado about nothing?
    iClaudius likes this.
  18. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    The OP has a Prius c, which does not have a bladder.
    ztanos and PriusCamper like this.
  19. poser
    poser Junior Member
    Alberta
    540 miles one way? you should do it on 2.5 tanks return home. 43mpg isn't much, slow down a little, you'll end up saving time by not fuelling up as often. AND, you'll save money too.
  20. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
