GET YOUR DEDICATED SNOW TIRES NOW !!!
Discussion in 'Prime Main Forum (2017-2022)' started by Rob43, Sep 24, 2019.
  1. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    What rims are you using on prius prime 2020 and what about tpms ? Thanks in advance
  2. Mendel Leisk
    42,325
    These'll work:
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
    steel rim lug nuts, part no: 90942-01007 (plain, open-ended, galvanized)
    The have advantage of having correct hub opening, kosher Toyota rims. I got mine for $70 CDN apiece in the fall of 2010. They seem to be asking exhorbitant prices on EBay, but do yourself a favour and ask a few local dealerships, you might be pleasantly surprised.
    I put a black ABS pipe end cap over the center hub (with rubber band pushed on first, to fill the slight gap). That holds through winter, never any problems, and protects the hub from rusting. Also, the lug nuts are just open ended, but I find putting a drop of light oil on the tip of each one keeps them from rusting. Say every coupla months.
  3. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    This on on 2020 prime ?
  4. Mendel Leisk
    42,325
    Yeah it's compatible.
    Well having said that, you'd want to trial-fit the rim, it is a dfferent generation. But it works a charm on our 3rd gen.
    I'm still on the 2010 purchased X-Ice lol, only about 85K kms on the car.
  5. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    Ok thanks tire rack lists different rims but thanks for your info
  6. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    Looking for some one with 4 gen what rims they have used.and tpms ?
  7. Mendel Leisk
    42,325
    If you can get away with it just fugedabout tpms?
  8. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    Ok thanks
  9. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    Still would like hear from prime owners with dedicated rims for snows.what rim they used and tpms ?
    #289 kinglew, Dec 1, 2019
  10. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    I have steel wheels from tire rack on my Prime. They sold TPMS sensors as an option, but I didn't opt for them. The hub opening is roughly correct, but it has more tolerance than a factory alloy wheel. I get extremely slight vibration on the highway, so I wonder if it's that, or maybe my tires just aren't balanced perfectly. It isn't bad enough for me to do anything about it.
  11. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    Thanks that the input I am looking for.
  12. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I bought MB ICON 15 inch alloy wheels and Michelin Xice3 tires together from Discount Tire for my 2017 PRIME last year without TPMS. At sales price and rebetes, MB ICON alloy wheels (final price at ~$60 each) were less expensive than plain black steel wheels they had in stock. Buying wheels and tires as a package, you can also save on mounting and balancing cost that are included free. That's if you are willing to install them on your car DIY. My final cost including everything (tires, wheel, mounting, balancing, rubber valve stems. lug nuts, tax, and free shipping) came to be less than $500 total. I use external TPMS on my car.
    #292 Salamander_King, Dec 1, 2019
    hill likes this.
  13. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    thanks for the info just order rims from tire rack buy x3ice from local tire shop.still decide about tpsm
  14. Mendel Leisk
    42,325
    Pick up the phone and try a few local dealerships for the Corolla rims. They're head-and-shoulders better than TireRack one-size-fits-all. Or don't, your call.
    Again, picked mine up (in 2010) for $70 apiece, which is about $52.50 US.
    You get a rim with hub opening that fits, and 5 lug nut holes. Some of the generic rims have 10 lug not holes, look like swiss cheese. And just an oversized, lipless hub opening, You can do the the ABS end cap trick with those, so in a NY winter or two you'll be looking rusted up hubs. That's going to happen anyway, but the end caps help a lot. Paint them with boiled linseed oil or similar will help some.
    #294 Mendel Leisk, Dec 1, 2019
  15. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    order my rims on the way
  16. Mendel Leisk
    42,325
    Supposed to start snowing here any minute. Freezing my butt off, taking the dog out for a quick morning pee. Brrr.
  17. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    The rims tire rack sent me are not one size fits all, they are specific to this Toyota hub size. They have the correct hub bore, and 5 bolt holes. That said, they are probably a bit lower quality than factory rims (I mentioned the tolerance in the hub bore), and if I were to buy again I would probably go with Corolla steel wheels.
    At least aftermarket steel wheels (probably) aren't a safety issue. I'm not a fan of aftermarket alloy wheels because many of them are built and tested to lower standards than factory. For example they might be cast instead of forged, and they probably don't undergo as much testing and quality control specific to the vehicle (for example crash testing). I've heard of aftermarket alloy wheels cracking, but that's pretty rare with OEM ones. Some aftermarket alloy wheels are probably perfectly fine, or maybe better than OEM. Problem is there's no good way to tell.
  18. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    I made my decision order rims done. next tpsm
  19. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    Gen 3 rims don't fit prime
  20. Salamander_King
    11,024
    8,978
    New England
    ASAIK, they do. Are you talking about Gen3 OEM wheels? Gen3 touring trims have optional 17inch rims, but they also fit on PRIME, if that's what you are asking.
