GET YOUR DEDICATED SNOW TIRES NOW !!!
Discussion in 'Prime Main Forum (2017-2022)' started by Rob43, Sep 24, 2019.
  1. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    All they would need to do to make TPMS more user friendly would be:
    - Store 8 (or 10) TPMS sensors and let the driver switch between two sets of wheels in a menu
    - Show the tire pressure of each sensor on a display
    As it is now, TPMS is a huge hassle, and enough of a barrier to keep some people from getting winter tires/wheels. I think the benefits of winter tires outweigh the benefits of TPMS, which is why I run winter tires without TPMS.
    Regarding cloned sensors, my Prime picks up the TPMS signal from my summer wheels that are stored in the garage, and the TPMS light doesn't come on until I've been driving for about an hour total each day. I imagine cloned sensors could cause even more confusion since the car wouldn't know which sensors it's getting a signal from.
    Rob43 likes this.
  2. Mendel Leisk
    42,373
    Mazda seems to have done better. New sensors do need to be introduced, typically by a dealership visit, but from then on, owners can swap between two sets of tires, no special equipment needed:
  3. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    A few European auto makers allow storing two sets of TPMS ID's in the vehicle ECU but that might be because the use of winter tires is required in some European countries. Toyota seems to be rolling out the display of all tire pressures as new models are introduced but whether or not they will do it on their less expensive vehicles is unknown.
    TLMS isn't a hassle to me or my friends who have winter tires with pressure sensors. I gladly spend a couple of extra minutes per vehicle twice a year to do the reprogramming with an inexpensive handheld tool to get the safety benefit. I'd rather get an advance warning in snowy cold weather that a tire is going flat so I can get to a service facility before it does. Maybe TPMS seems mysterious to some people but it's really pretty simple.
    It is normal for the vehicle TLMS system to not issue a low pressure warning until the vehicle has been driven a while . I store our extra wheel/tire sets fairly close to our vehicles in the garage but their pressure sensors go into sleep mode when stored and aren't/can't be recognized by the vehicles. The pressure sensors used on our Toyotas "wake up" due to tire rotation which means that only sensors on wheels mounted on vehicles are recognized.
    #143 Offline, Oct 16, 2019
  4. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    OK, I received my 72.6 to 54.1 Hub Rings.
    The steel wheels I bought are 15x6 with a hub bore of 72.0mm's, could I rely on just the 5x100 bolt pattern & forget about using these hub rigs, Absolutely.
    But I want to "try" to install these hub rings just to see if I can, remember that hub rings & steel wheels usually don't play well together.
    When using an alloy wheel, hub rings would normally be installed on the backside of the wheel where they were designed to fit. In this case, the only way to install these hub rings will be on the front side of the wheel. Will this work, not sure, will they permanently stay in place, I don't know....
    As you can see from my pics, these hub rings are slightly to big to fit on the first try, I will need to "massage" them in. After I took these pics I spent a few minutes tweaking things, I'd say my realistic difference 0.30mm's (~0.12") for each wheel.
    Rob43
    #144 Rob43, Oct 17, 2019
    benagi likes this.
  5. Offline
    646
    240
    Lenexa, Kansas
    Tapered lug nuts work well for centering the steel wheels I bought for the winter tire set up on my wife's Prius v - no need for hub rings. The non-tapered lug nuts for the alloy wheels that came on the car can't center the steel wheels. Get tapered lug nuts for your steel wheels if you don't already have them.
    benagi likes this.
  6. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    I got em, I just like to try out things like this...
    Rob43
    benagi likes this.
  7. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    I will have hub rings for some Enkei wheels. My thought was to rebore the original steel spare wheel, but I can't find anyone to do it. Since the hub rings do not work well with them then maybe I need to consider runflats and just remove the spare.
    moto g(7) power ?
  8. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    My experience also. This is the difference between the lug-centric steel wheels and the hub-centric Toyota alloys.
  9. PT Guy
    1,085
    713
    Not my experience at all. The TPMS winter wheels are stored right now. When I put them on next month there is nothing extra to do to get the TPMS system working. Bolt & go. These are aftermarket sensors supplied by Discount Tire when I bought the wheels & tires.
  10. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Are the aftermarket TPMS sensors in your winter wheels cloned? How close are the winter tires stored in relation to your car at home when you have summer wheels with OEM TPMS sensors?
    m8547 likes this.
  11. Mendel Leisk
    42,373
  12. Offline
    646
    240
    Lenexa, Kansas
    Here's a link to an article that explains how the accelerometers in sensors cause them to transmit information only during wheel rotation and how electronic TLMS tools can query sensors on wheels that are not rotating: TPMS Sensor IDs: Why, Where and When -
    I store winter/summer wheels/tires in the same garage in which the vehicles are parked since the garage is sort of cave like under the house and temperatures in it are moderate all year. The garage in our previous house was above ground. Temperatures in it could vary by over 100 degrees Fahrenheit so I stored wheels/tires in a basement when they were not in use. A photo of wheels/tires currently stacked on MaxxHaul tire dollies is attached - excellent inexpensive tire dollies with lug nut storage compartments that can also be connected together and used as a creeper.
    I reprogram vehicle ECU's immediately after doing the semi-annual changeovers. If I didn't, the low pressure warning in the instrument cluster would light up within a few miles of driving due to a mismatch between the ID's of sensors on the mounted wheels and the ID's stored in the vehicle ECU.
    If it wasn't for the accelerometers in the sensors, their batteries would be exhausted very quickly instead of the 8 to 12 years that sensor batteries usually last.
    #152 Offline, Oct 19, 2019
  13. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    An interesting read, though geared more to Canadian extreme winter conditions.
    I was glad to see my newly bought $57 dollar Hankook Winter iCept iZ2 tied for first place, that info backs up the Norwegian publication Autofil testing that's located on page 7 of this thread.
    Rob43
  14. Mendel Leisk
    42,373
    A high percentage of Canadians live close to the US border. And just for an example, winters in my area are balmy, say compared to North Dakota.
  15. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    The Canadian border is still located North of the United States, isn't it ? ;)
    Rob43
  16. Salamander_King
    11,024
    8,980
    New England
    Since you reprogram ECU at each tire change, the TPMS light in your car works fine even if you have a set of winter tires in your garage while you have summer wheels on. I don't have TPMS sensors in my winter set of wheels and during winter my summer wheels with sensors that are registered to ECU sit in the garage right next to where my car parks at home. I experience exactly the same thing as what @m8547 describes.
    Yes, the car's ECU is sensing the existence of uninstalled but registered TPMS in the garage near the car when the car is at home. This causes the TPMS malfunction light to be unlit for the first ~20 miles. Once it comes on, it stays on. When I park my car at work with my winter wheels without TPMS, the light stays on immediately when I start the car after 8+ hours of parking, but when I come home and park my car near the summer wheels with the sensor that is stored in the garage, my cars TPMS light goes off. The concern m8547 raises is a legitimate one. If you have a set of "cloned" wheels stored near the car, now you have two sensors with identical ID registered to ECU that may report conflicting data.
    #156 Salamander_King, Oct 19, 2019
  17. Mendel Leisk
    42,373
    I'm in Hollywood north. :whistle:
  18. Offline
    646
    240
    Lenexa, Kansas
    Well, it's not supposed to work that way. I'll experiment when I mount our winter tires next month by not reprogramming the vehicle ECU immediately and will see if the vehicle ECU's recognize the sensors on the stored wheels when we pull into the garage.
  19. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    I agree it's not supposed to work that way. The sensors should go inactive when the wheels are stored. Maybe a signal from the car is waking them up?
  20. Mendel Leisk
    42,373
    I alternate between stock wheels/tires with sensors, and corolla wheels/snow tires without. Through winter the stock wheels are in the garage, next to the car when it's parked. I have the TPMS warning light on. It maybe takes a while to wake up as I leave the garage, due to the proximity of the stock tires in the garage, but definitely see that light a lot.
    Not sure about that.
