Getting 17 miles of EV range
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Edsvfr800, Jun 9, 2013.
  1. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    I love the warmer weather. I work 15 miles away from home, so I thought I was just out of range with this car. That was until I gave it a shot yesterday. I went 15 miles with 2 miles to spare. Temp 65 degrees. Charged up at work and went home with 1 mile to spare. No gas used....it is 4.09 a gallon here. I went the speed limit on the roads and it took 35 minutes to get to work. I am averaging 320 miles per gallon since my fillup on may 3rd. I love this car....
    F8L, awall and retired4999 like this.
  2. benalexe
    benalexe Member
    198
    30
    Commack, New York
    Wow that's insane. The most I get is about 9.5. You must be very light on the pedal? Flat road. No stops etc,
  3. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    Definitely soft on the pedal, about 5 or 6 stop lights and mostly flat roads. FYI my starting EV reads 14.6 miles.
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That warmth is the key.
    Mine drops to 9 in the dead of winter in Minnesota.
    This was my best last summer...
    It most definitely fluctuates with the temperature.
    Edsvfr800 likes this.
  5. bisco
    52,766
    right on!(y) did 15.5 yesterday with 3.0 left when i got home. average speed = 16mph:whistle:
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    15 miles to work in 35 min is an average speed of 2.3 25 mph. Must be really long red lights.
  7. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Check your math again. At a constant speed it would about 25-26 mph. The most efficient EV speed for cars is typically 15-20 mph so he's actually driving a little too fast. :)
    At an ideal speed you might hope to get close to doubling the EPA estimated EV range. So if someone had ideal conditions they might hope to get 20-22 miles from a Plugin Prius.
    mmmodem likes this.
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    note, the key thing: averaging 320 mpg not 999mpg which explains the 17 miles EV. The best I got last summer was 15.3 miles EV when ICE kicked in at 15.3 miles. :D And that's when I was going about 15 mph
  9. El Dobro
    El Dobro A Member
    7,102
    3,282
    Just won't happen around here, but when I shut down and the read-out says I got anywhere from 100 to 199 mpg for my commute, I'm satisfied.
    :D
    F8L likes this.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    This year, May 18, 2013. One of the few warm days 80+ degrees f we have had this year. When I leave my house I have to go 300 feet down to the river bottoms and 300 feet back up and then the reverse going home. This was a round trip all EV best I have ever done! :D
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Yeah.....I'm on flat land.... no inclines or declines to add additional EV miles to my totall EV
    SGH-M919 ? 2
  12. afarias
    afarias New Member
    Shoreline CT
    Hmmm...temp in CT is in 80s, 90s and my starting EV has gone down to 10.2 from 11.7 in dead of winter. Any guess why since warm weather seems to be pushing everyones EV miles up? Just hit 5k miles. Congrats to you guys pushing 15+
  13. bisco
    52,766
    you're 'starting ev' is just an estimate based on past performance. how many ev miles can you drive?
  14. Biking Maniac
    Biking Maniac Five Prius – have not sold one yet!
    58
    Menomonie Wisconsin
    2001 Prius
    Great EV range! I made it a little over 17 last week - must be the methane in our Wisconsin air!
  15. Frank Perkins
    Frank Perkins Member
    129
    66
    Fairfield, Connecticut
    I'm in ct too and only hitting 11 max EV estimate. I can get about 12 though. Check to see if your fan is on. That takes a mile even if AC is off.
  16. retired4999
    2,652
    627
    Eau Claire, Wi.
    Super methane!
    Nice to see your still visiting! :D
  17. Frank Perkins
    129
    66
    Just though I would mention with about 85-90 degrees today I was given a 11 mile range estimate. However, I drove 9.5 miles and had 3 miles left. I guesstimate even though I only had an initial 11 range estimate, I could have went about 13.5 miles. The point is don't stress the estimated EV range.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    9.5 + 3 = 12.5 miles:D
  19. bisco
    52,766
    but we all know, with franks hypermiling skills, he could stretch it to 13.5.(y)
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    he already drove 9.5 miles and has 3 miles left, that was the discussion.:p
