Getting 17 miles of EV range
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Edsvfr800, Jun 9, 2013.
  1. Frank Perkins
    Frank Perkins Member
    129
    66
    Fairfield, Connecticut
    Sorry for not being precise, but I was estimating. If you need to know the gory details I actually drove .4 miles before I reset my trip B counter. I also only drive 8.8 miles so I was doing a little rounding and estimating how far I could stretch the last estimated 3 miles. :)
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yeah, I'm a little pit picky:rolleyes:
  3. Frank Perkins
    129
    66
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    :whistle:
  5. eyespii
    eyespii Junior Member
    48
    2013 Prius Plug-in
    Made it 17.4 miles in EV the other day, with a mile to spare! Of course, it took me about 45 minutes on the socal freeways that day...
    retired4999 and markabele like this.
  6. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    That's one of the many things that add up to make the PiP a really great car. In your case, not only did you go 17.4 miles in EV, if this was a non-hybrid like most of the other cars on the freeway next to you, the gas mpg would be horrible, even if a high mileage car. And compared to even hybrids, you wouldn't have had an engine cycling on and off a lot for those 45 minutes.
    Socal's made some major improvements in air quality over the last 30 years, but there is still a long way to go and the PiP helps a lot in the scenario you describe.
    chesleyn, retired4999 and rockerdan like this.
  7. hill
    9,008
    Whether you get 17 miles or 7 miles . . . here's a nice chart (from Tony on the 'mynissanleaf' site) that will show you how far you'll go, if you got a constant speed, and start with a full charge:
    http://dl.dropboxusercontent.com/u/35284720/postfiles/leafcharts/LEAFrangeChartVersion7G100.pdf
    It's pretty simple, if you're going fast, you'll only get a certain range per kWh. If you're going real slow, you'll go a whole lot farther. Thus, traveling at a constant speed under 35mph, you'll easily get over 6mile/kWh. Your range is thus a factor of kWh's available and speed (presuming moderate weather & level ground).
