Getting excited about next Gen. Prius Plug-in
Discussion in 'Gen 3 Prius Main Forum' started by 9G-man, Oct 29, 2008.
  1. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    details!!!
  2. PeakOilGarage
    PeakOilGarage Nothing less than 99.9
    334
    Pacific Northwest
    I can tell you from 3 months of experience that 5 kwh (Hymotion) is barely tolerable. I get about 25-40 miles (depending on city/highway) or 40-65 kilometers. That is gone in no time at all on a typical day.
    Having the ability to recharge at work or while shopping could greatly increase daily range. It just depends on how easily available an electric outlet is.
    If Toyota is only aiming for 20 km (12.5 miles) that is barely worth the trouble. That is likely only 2.5 kwh or so.
    The federal incentives start at 4 kwh. That would get a $2,500 federal tax credit for the buyer. So I beleive Toyota and all EVs or PHEVs will aim for that minimum amount of energy capacity in the battery.
    4 kwh would likely get a range of 15 to 30 miles, depending on the type of driving (city/highway).
  3. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    what i want and what i will settle for are two completely different things and that difference is greatly magnified by price.
    my MINIMUM request is the 20 k... i have a 7½ mile commute, i can plug in at work, so it will do. but that is not what i want, but give me that with a slight increase in price, and i will probably do it simply because the Pri has worked out so well for me even without any real EV range.
    now, what i prefer is to only use gas in extreme cases, iow, for extended car trips. so my dream (obviously when dreaming there is no fantasy-based upper boundary) situation is an EV range of 150 miles.
    i have only exceeded that 4 times in the past 14 months. so 4 times i would need gas...
    but then again, price becomes a factor and i think those survey results are based on price. what we need is a survey voting on real products. iow, give me a price point and range options to select. i bet the results would be much different
  4. misslexi
    misslexi Member
    130
    Renton, WA
    PeakOil I was wondering what makes your Hymotion barely tolerable? Are you getting less EV mileage than expected? Trouble with the system? Just curious since that system is not cheap.
  5. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    probably not... its all about NO OIL AT ALL. until then, we have not arrived. using less oil is nice, but...
  6. PeakOilGarage
    334
    Pacific Northwest
    It is "barely tolerable" because I am often at the limit of my battery range each day. If I had less than my current 5 kwh battery, with the 25-40 miles of range, I would be driving a regular Prius for half of each day.
    So when Toyota is rumored to be developing a Plug-In Prius that only chieves 12 miles (20 km) of EV range, my experience is that it would be a waste of time.
    I think most people would be surprised just how quickly that goes.
    Of course, I am sure that companies like Hymotion will just take whatever Toyota produces, then offer an aftermarket battery that extends the range. For example, the Toyota Plug-In might offer 12 miles of EV range, then Hymotion offers an aftermarket kit with an extra 50 miles.
    Having Toyota design a Prius to be a plug-in from the beginning would be a big step forward. The current generation Prius (2004-2009) is an accidental plug-in.
  7. FreddieVee
    FreddieVee Junior Member
    The Consumer Reports Conversion was done with a Hymotion L5 Conversion kit. There are quite a few threads about that system on this forum.
  8. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    oic.... thought it was a Toyota conversion
  9. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    I agree with PeakOil. I get 26 miles out of my Hymotion pack. I have done the FSM 52 MPH hack which has turned the Prius into a true EV vehicle. The hack requires the car to be restarted to be able to run on the engine again. I live in town and can run kids to and from school without the engine ever starting. This has provided new plus for the Hymotion. Before I was feathering the gas to stay under 32 MPH to avoid the engine start. Now, I press the gas without worry. I have found running pure EV my range is between 15-20 miles at best. I'm assuming closer to 15 miles, but my trip was over before the charge was completely exhausted. A smaller battery than the Hymotion to me would be a waste of time. I'd love to have 10 KW, but that would not be affordable at this time. My only other wish would to be able to recharge faster. Some days, I have a lot of little errands and the battery does not have time to recharge enough between trips.
    Those are my thoughts on the Hymotion conversion.
    ---Kent
  10. Liberanos
    Liberanos New Member
    Michigan
    Don't get too excited!! Mr. Katsuaki Watanabe says the lithium ion plug in fleet will NOT be available to the "Joe lunch box" comsumer any time soon.
    He would know I think.
    I'd love to have one too. But I'm not holding my breath.
    Paul
  11. patsparks
    10,664
    567
    Adelaide South Australia
    I tell you I am excited, I'm almost peeing myself.
    I have to go away tomorrow morning and I'm signing off now. Going away for 2 weeks but I'll check in when I can, no promises though.
    SO beware of where you are and what you're doing, PatSparks might be right behind you!!
    Take care group.
    Pat Sparks
  12. zenMachine
    zenMachine Just another Onionhead
    3,355
    299
    If you had a G1 or iPhone 3G you still could catch it live on your mobile. Safe travel...
