Getting good results with Tufoil oil additive
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dino33ca, Jun 9, 2014.
  1. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    Well, after over a year of delivery driving with my Prius I've been very happy with the car. I've put on just over 50k km's and the only thing I've had to do fix is the coolant control valve. The car has really stood up. After reading here on this forum about some Prii losing oil I went with a high quality synthetic, first Mobil1 extended, then Amsoil. I also started using Ceratec from Lubrimoly. The Ceratec seemed to give the car a little more torque and smoothness but I didn't notice any real gains in mpg which is ok because I'm primarily using it to extend the engine life, at least hopefully. I started using Tufoil at my last engine change and since then I've been breaking my personal mpg records and the engine seems as smooth as she could possible be. For example, I got 4.5/100 km's on a day time delivery shift and 5.0/100 km on a Friday night shift. Personal records for my car. I don't want to make claims of how much better it is percentage wise or other as this is purely non scientific, but I can say with confidence I'm seeing excellent results since adding Tufoil. In this particular oil change I've got 3 liters of Amsoil 5/30, 300 ml Ceratec, 500 ml of Lucas Synthetic oil stabilizer and four ounces of Tufoil. I put the Tufoil in after driving for 1500 kms so that the Ceretec (ceramic friction modifier) could plate first. I started seeing personal record breaking mileage after I put the Tufoil in. I decided to give Tufoil a shot after reading customer reviews that were nearly perfect in positive feed back. Just wanted to share this with others. Here is a description of tufoil from Amazon...
    Tufoil Engine Lubricant is Guinness Book of World Records certified as "The World's Most Efficient Lubricant." Slipperier than Teflon to make engines start easier, run cleaner, faster, and longer. Tufoil engine lubricant has been tested by the US Government at the National Bureau of Standards. Their results prove that the surface friction of Tufoil (.029), makes it the most slippery substance known to man! Tufoil is a super-suspension of micro-miniature PTFE particles and soluble Molybdenum, permanently suspended in oil. All moving parts become coated with PTFE particles which reduce friction and wear and will not clog filters or oil openings. Safe for all gas and diesel engines. We recommend you change your oil and filter every 3,000 miles. However, many of our customers find that their oil is still clean at this point because of Tufoil's ability to cut friction and wear. They will then make the decision to extend oil changes accordingly.
  2. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    I have never been happy with ANY oil additive I've ever used........over more than 50 years.
    I think a Teflon based product caused the valve guide seals to go bad on a Honda many years ago.
    AND I believe that the owners manual says "Do NOT put any additives in the oil."
    Proceed at your own risk.
  3. Former Member 68813
    3,524
    981
    US
    How did you came up with this specific recipe? Trial and error?
  4. Easy Rider
    982
    210
    N. Central Florida
    You have GOT to be kidding.......right ?
    This is just a troll......right ??
    If that is true there is only one word that I can use to describe it: STUPID.
    I sure hope you never have an oil related engine problem that might be covered under warranty.
    THE OWNERS MANUAL SAYS TO NOT PUT ANY ADDITIVES IN YOUR OIL.
    Certainly not a cocktail of 3 different ones.
    P.S. Your posts would be a LOT easier to read if you would put some white space in them.
  5. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    I started with true synthetic and Ceratec 50k kms ago with the hope that the ceramic coating would protect the engine from wear. I've read of users getting impressive uoa's with Ceratec. 20k kms ago I started using synthetic oil stabilizer thinking that it would be good for the Prius as the engine is always cutting in and out. The Lucas is suppose to help leave a thicker film of protection on the engine, and they claim it suppose to extend the life of valve stems. Many race drivers and truckers swear by it. The stuff gets knocked around at Bob is the oil guy site but it does get very good customer reviews. I didn't see any real noticeable mpg increases until I added the Tufoil. Tufoil is a microscopic ptfe particle that does not get stuck in the oil filter or clog passages, unlike Slick 50 which was too thick for engines filters and passage ways. I use only 4 ounces of tufoil which works out to five bucks per oc. My oc cost is about $60 but considering I can easily double the recommended oc change it would work out to $30 per oc change at recommended intervals.
    My goal is to get 500k km's out of this car which may be a tall order as I use it for severe driving (deliveries) probably 60-70% percent of the time. So far, so good. I'm at nearly 190k kms and am not using any concern able amount of oil, the engine is smoother than when I bought it and I'm getting personal highs for mpgs, so I'm very happy with the results and will continue using the combination. I'm not trying to convince anyone to try this formula, but rather, I'm just sharing observations and ideas.
    My second gen owners manual says nothing about not using oil additives, and I can't imagine why it would as all modern day oils use additives in their products.
    I forgot to say that I use an oversize oil filter Mobil1.
  6. Easy Rider
    982
    210
    N. Central Florida
    Of course they do. Ones that are tested by chemists and engineers of both the oil companies and the engine makers.
    Not ones that are hyped by marketing more than scientific value.......and mixed into an unknown cocktail by a rank amateur.
    What you are doing is absolutely dangerous. You don't know what you might end up with when those extra additives combine with each other and with what's in the oil already.
  7. engerysaver
    engerysaver Real Senior Member
    426
    130
    Tyler, Texas ; USA
    In my time; they said multi-grade oil will never work:LOL: ..... but now it is the norm!!
    When synthetic oil first came out; they said, it is NOT real oil, it will not work:ROFLMAO: ..... yet it is recommended now!!
    Their are two types of additives; one with zinc or teflon base material that coats the ice; the other type will clean by using solvents to strip the sludge and deposits. They are opposite from each other; One puts on; the other takes off!!
    It will not be wise to mix the two types together:eek:!! I'm not saying you did; because I don't know about those brands. It appears that you are using the coating type; .... which, I think will be the FUTURE in oil? (y)
    Only time will tell? .... Big oil keeps big secrets!!:( It's all about MONEY!!:mad:
    Keep us posted on your results!!:)
  8. Easy Rider
    982
    210
    N. Central Florida
    When engine parts get coated with "stuff" it is often called SLUDGE. :whistle:
  9. engerysaver
    426
    130
    Tyler, Texas ; USA
    If you use synthetic oil; what do you think you are putting in your car?:whistle:
    Do some reading on PTFE !!:D
    Polytetrafluoroethylene - Wikipedia, the free encyclopedia
  10. engerysaver
    426
    130
    Tyler, Texas ; USA
    Synthetic oils are made from alkylated aromatics, synthetic esters and polyalphaolefin (PAO).
  11. ETC(SS)
    6,496
    Posts like this are a poignant reminder for why I don't buy used cars.
    I don't have any problems with people performing physics and chemistry experiments with their cars, since I'm not that kind of control freak.
    I'm bemused by the "It's a conspiracy theory!" claims for big oil, and you know what???
    Let's pretend that the kooks are right and "big oil" is sitting on the secret to improving your mileage by 25%.
    People usually buy chemicals and special "bolt-ons" for 4 basic reasons:
    Mileage, Horsepower, Longevity, or they just love their baby, and want to give it the automotive version of nursery water.
    As far as mileage and horsepower????
    I'm thinking that "big car" would have figured it out by now, and that if any of this snake oil resulted in a measurable increase in MPG, then Toyota would be putting it in their cars from the factory so that your "record breaking mileage" could be added to THEIR EPA estimates. ;)
    They would put camel urine in the crankcase if it would result in a 2-percent increase in their 50-MPG EPA estimate because a sudden up-shift from 50MPG to 54MPG would make it onto the API wire service.
    How about Dodge?
    They would LOVE to up their CAFE scores to compensate for all of the Challengers and Rams in their fleet!!
    They'd use Am$oil and Tuftoil combined!!!
    AND the snake oil manufacturers would give them a steep discount because of volume and for the press!!
    Camaro and Mustang owners?
    Substitute BHP for MPG and the same theory applies.
    As far as Longevity is concerned?
    Neither "big oil" nor "big car" could give a rats about how long your car lasts, either way.
    They just don't want to have a Renault reputation and they want the car to hold together for the OEM warranty period.
    Period.
    My theory is that most of this crap actually does more harm than good, and that most of the people that use additives like this are in the 4-and-out club.
    It works like this:
    They buy a car... and either torture or baby it for 4-5 years.
    Either way, the additives are their way of buying flowers and candy for their car either because they love it or they're mistreating it.
    4-5 years later, they're driving car # next and some poor sap is having to deal with the results.
    In other words.....
    Most of the people who do stuff like this never keep their cars for 250,000 miles, when any repeatable data proving or disproving their claims would be apparent.
    That's my theory.
    Like it or don't.
    I use no additives, and I usually keep my cars for >10 years.
    That way?
    I don't have to worry about buying a car that's been "experimented" with! :)
    Have a nice day!
    KhaPhoRa likes this.
  12. Mike500
    Mike500 Senior Member
    2,593
    763
    That's the "If god wanted man to roll around in cars, he would have put wheels on out feet at birth." attitude.
    I am sure that some additives and some "bolt on" modifications help, but like anything else, it's "the particular item."
    I've used Tufoil, before and had good results. From my findings, it if composed of PTFE and molybdenum disulfide.
    With what I have heard about Teflon or PTFE, I NOW believe that it is the molybdenum disulfide that has the most benefit.
    On that account, I mow use a molybdenum disulfide additive. Mercedes, BMW and Porsche dealers all over Europe have recommended it and have had good results without any negative effects.
    Whatever you do, it is your own "peace of mind" that means everything.
    #12 Mike500, Jun 12, 2014
  13. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Since I started using tiger repellent, I have seen no tigers in Mississippi. Can you show any history of Prius engine problems that squeezing snakes for their oil is solving?
    Merkey likes this.
  14. Mike500
    2,593
    763
    Snake oil was first sold to humans for internal consumption.
    Chemical analysis revealed that No snakes were harmed or killed in making "snake oil," and it contained NO real snake oil.
    And, as for engine wear, are you saying that there is NO engine wear in Mississippi?
  15. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I am unaware of any Prius engine in Mississippi that failed with Toyota's recommended oil and change interval, correct. Ask again in 40 years and I may have better stats, but the first 10 seem trouble free.
  16. Mike500
    2,593
    763
  17. ETC(SS)
    6,496
    Actually.....
    To play devil's advocate on behalf of Mike, the 'Moly-be-damned' stuff probably won't hurt, and there is some evidence that an abnormally large number of Priuses suffer from what I consider to be greater than normal oil consumption after 100,000 miles or so.
    I personally think that the excessive wear is from neglect stemming from people confusing a 10,000 oil change interval with a 10,000 oil check interval.
    Most of the people who put oil-o-snake in their cars probably care enough to actually check their oil volume regularly, and this is more than likely a large contributor to their longevity gains.
    I always carry jumper cables in my trunk.
    I always get lunar mileage out of my engine.
    Therefore.....
    Jumper cables will help to mitigate engine wear.
    I respect Mike's opinion, and peace of mind is probably well worth the price of admission into the additive club.
    However....(comma!)
    I'll stick with jumper cables.
    They're handy for helping stranded motorists too! ;)
  18. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    This thread reminded me of this.
    Merkey likes this.
  19. Mike500
    2,593
    763
    Conventional wisdom leads one to believe that the best functional cylinder walls of an engine functions best with a highly polished smooth surface.
    That is NOT the fact.
    All cylinder walls are prepared with a cross hatched "honed' pattern of striations-striations or cavities in the cylinder walls that retain lubricant.
    Oil is retained in these striations.
    Wear occurs when these micro striations are polished out by wear as to no longer retain oil or lubricant.
    Unburned fuel or ethanol in gasoline washes oil out of these striations which promotes wear.
    Once the striations disappear or become polished out, they no longer retain as much lubrication as before. Oil passes across the cylinder walls and the surface of the rings. That's why cars "burn oil."
    Molybdenum disulfide is a dry lubricant and is retained in the striations even when there is no oil fed or pressurized by the oil pump.
    This is he benefit of MoS2 lubricant add to the oil.
    It, in smaller quantities, is part of the makeup of most motor oil additive packages, already.
    engerysaver likes this.
  20. ETC(SS)
    6,496
    The above is absolutely true, and it will be interesting to see if 30 years from now the OEMs start putting friction modifiers into sub-liter engines that crank out 300-400 BHP.
    I'm thinking that a 600cc motor that cranks out 150BHP might need "miracle-lube" and designer oil, but based on what I'm seeing in the motorcycle industry these products might not produce 200,000 mile engines.
    The smaller these little guys get, the more you're going to need even the diminutive advantage that the (insert base element here) based additive will yield.
    You have to remember.....
    20-30 years AGO we were barely getting 100BHP out of a 2-liter motor.
    However (comma!)
    If I'm able to consistently get 200-300,000 miles out of today's motor using nothing more than Luddite oil, then aren't these products a solution desperately searching for a problem to solve???
    Most cars don't die from broken engines.....or even badly worn ones.
    I don't have numbers to back this up but I'm presuming that even 15 years after launch, most Priuses (like....99-percent) are still being parted out in junk yards from non-engine related failures.
    In fact....you can regularly buy a <$500 unit from a motor-doner that was killed in an auto crash.
    Maybe "snake-oil" is overly pejorative, but hey....if you're out on the sharp end of the stick, you have to have a thick hide.
    I say that for a 2014 Prius whose owner is planning to put less than 300,000 miles on, and who regularly checks their filters and fluids, it's unneeded.
    It's like the nursery water example that I provided.
    If that makes me a Luddite?
    Well, that's probably true as well, but I'm a Luddite that has studied the issue, and has made an informed decision with demonstrative results., and I have a thick hide as well.
    Poke away! :)
    No claims here for "record breaking efficiency" of "better pedal response."
    GOOD LUCK!
    Edit: I spent an hour reading up on Archoil. It seems that they also make firearms lubricants and fuel additives. They're an interesting company.
    I especially liked the Bell Labs reference, since I work for Big Phone, and we don't use additives for our standby generators (I have 4.)
