getting iPhone directions while listening to other things
Discussion in 'Gen 4 Prius Audio and Electronics' started by dangrass, Jul 26, 2016.
  1. dangrass
    dangrass Junior Member
    47
    Oakland, CA
    I have a 2016 car with the base audio system and connect my iPhone 6s via USB. I've noticed that when listening to music from the phone I get voice driving directions, but if I'm listening to the radio, no directions. Seems that if the phone is the selected audio source it all works, but if it's not...it doesn't.
    Is there a way, when listening to the radio, to have the system mute the radio and provide directions as it does when getting content from the phone?
  2. Chris Clark
    Chris Clark New Member
    26
    San Antonio
    Are you using navigation through your iPhone?
    Have you tried listening to the radio through an app on your iPhone such as iHeartRadio?
  3. dangrass
    47
    Oakland, CA
    Oh, I'm sure that would work, but I'd really like to use the radio radio. You know, that technology where they send audio information via amplitude or frequency modulation. It's amazing how far these signals can travel...and it's free!
  4. Sabby
    Sabby Active Member
    295
    127
    SoCal
    There is a setting in your maps program that allows this. The car should be on, Bluetooth connected and open settings on your map program. It will then handle the direction prompts as if it is a phone call
  5. dangrass
    47
    Oakland, CA
    Thx. I see that seems to have done the trick.
  6. StarCaller
    StarCaller Senior Member
    1,283
    732
    Cedar Crest, NM, USA
    details how you got it to work?
    BION
    StarCaller
  7. dangrass
    47
    Oakland, CA
    Sure. On Google maps you tap the menu icon at the upper left, then the settings icon, then navigation settings, then turn "play as Bluetooth phone call" on.
    On iOS maps when the phone is connected to the car there's a speaker icon at the lower right. Tap it and select Toyota Prius (or something like that)
    I haven't checked to see if the iOS settings stick or whether you need to select them each session.
    Dan
