Getting ready for Hurricane Irma
Discussion in 'Generation 1 Prius Discussion' started by FireFighterHill, Sep 7, 2017.
  1. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Well I just ordered overnight shipping a 3000watt inverter to install in my Prius. if the power goes out I should be able to run a window ac unit and my mini fridge. Im not sure whats the biggest inverter anyone has installed. According to my calculations the most I should ever draw even peak will be right around 1800 watts. The inverter I ordered will do 3000watt continuous and 6000 peak. Im near Orlando so im hoping we dont get the worst of it. My thoughts and prayers to everyone in its path.
    Data Daedalus likes this.
    52,888
    all the best with the storm!(y)
    how do you install an inverter that big, directly to the hybrid battery?
  3. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Its not getting connected directly to the hybrid battery. I will connect it to the 12v battery. I have a large AGM Optima redtop in mine, and i might even connect a second identical one I have in Parallel to act as a buffer for any sudden high amp draws. The prius can be left in "ready" mode with everything turned off and will cycle the engine to charge the 12v and traction battery.
    To connect directly to the traction battery id need an inverter that could convert 300v DC into 120v AC. They do make them, mostly for computer server applications. But they are very expensive. Ive been keeping my eye out for a used one.
    Data Daedalus and bisco like this.
    52,888
    i've read you can only put a 1000w inverter on the 12v, but i have no idea why.
  5. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Ive read on other forums of guys using everything from 1000 to 3000 and not having any problems. I dont think any of them ever got near the true capacity of the inverter though. I dont plan to either. I just want that extra room. I can always disconnect it from the prius and connect to a different vehicle if the load I need to run becomes to much. I should be able to keep a close eye on the car from inside my home using my bluetooth OBDII reader and the Torque app.
  6. benkhanobi
    benkhanobi Member
    123
    50
    SW Florida
    The Prius uses a 201 volt to 12-14 volt DC-DC converter to charge the 12 volt battery- there is no alternator. Look at the power wires going to the battery - they are fairly small cables, because the 12 volt battery doesn't need to produce the starting motor current of a car. That said, your 1800 watts of load would be E x I = P , 12v x 150 amps= 1800 watts
    Too much current for the Prius DC-DC converter. Also the wires back to the converter are way too small for that load. Send the 3000 watt inverter back. Look at the size of those battery wires- if they are #6 wires- 60 amps- that would be a max of 700 watts. Personally, unless I knew from Toyota that the converter was designed for 700 watts continuous load, I wouldn't go any more that 300 watts continuous load.
  7. bisco
    52,888
    pretty sure bob wilson pulls close to a thousand watts, and maybe #4 wire?
  8. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    If you take too much from 12V system 12V battery will drain. I don’t know the exact limit for gen 1 Prius but around 1000w might be close. But as OP has “large AGM Optima” it can provide current for some time until it gets empty. So as long as aware load is not more than about 1000w he should be fine if high power consumption event don’t last that long. Half an hour with that 1800w load might come close to the limit with that one large optima.
  9. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    I'll keep a close eye on it, do some screen shots with the Torque app as well as take pictures of the LCD screen diagnostics on the inverter. I'll let everyone know how it does. In actuality after looking up the model number of both my mini fridge and my window ac unit. The mini fridge power draw between 0.5 and 1 Amps and 55 watts. The window ac at 4.9 amps and 520 watts. I think im safe. I bought such a large inverter because the price different between it and the 1500 watt inverter I was considering was only about 65 dollars.
    Frigidaire 3.1 Cu. Ft. Compact Refrigerator Silver Mist-FFPS3122QM
    GE® 115 Volt Room Air Conditioner | AET05LQ | GE Appliances
    mmmodem likes this.
  10. bisco
    52,888
    do those units have start up specs vs run specs?
  11. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Bisco, they don't list that.
    And here's the inverter I ordered.
  12. bisco
    52,888
    i'm no expert, but i believe there is a start up draw to a compressor. don't know if it can be calculated from run draw. maybe @valde3 knows.
  13. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    And my reasoning for using 2 batteries in parallel is to buffer the car from a spike in amp draw when the compressors start.
  14. valde3
    2,002
    751
    Finland
    No it can’t be calculated. You may kind of estimate it. But it doesn’t really matter a good big optima will supply enough power to the inverter that can supply enough power for the startup.
  15. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Good luck with that.
    To produce 1800 watts, it will draw (or try to draw) about 150 amps from the 12 V system.......continuously.
    That is WAY, WAY beyond it's design capability, no matter how many batteries you have connected.
    What's the cost of that 3KW inverter, as compared to a 3 KW portable generator ??
    I think this is a very BAD plan.
  16. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Since making the original post I have done more research and revised my expectations. I had to pull the trigger quickly on the inverter if I wanted any chance to get it before the Hurricane gets here. I just went out and looked at the fusible link on my car, its 120amp. If It tries to pull over 120amps it will melt the fusible link. I have more of these fusible links on hand. Theoretically I should be able to pull 1680 watts at 14 volts before going over 120amps . Or 1440watts at 12 volts. I plan to be careful with my loads. Just cause I bought a 3kw inverter doesn't mean im going to use the Prius to try to pull 3kw. I prefer to go bigger than I need so that im not pushing a tool or appliance to its limit. Id also like to be able to use this inverter in other applications if need be. To use its full capacity id need be able to pull 250amps at 12 volts. This inverter should be able to stay nice and cool even with a 1kw continuous load.
    A 3kw generator is at least a grand. The price can vary greatly depending on brand, type, fuel, etc. For example a Honda EU3000i 3kw quiet inverter type is about 2500 bucks. Thats more than my entire Prius is worth.
  17. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I didn't realize inverters had gotten that inexpensive. Nothing wrong with having it oversized as long as you keep an eye on it. I wouldn't go over 1kw load in order to protect the car. As for the question about startup amperage, our rule of thumb in the electric shop was that startup current is about 600% of FLA (full load amperage) until the motor is up to synchronous speed. Which gets thrown out the window with soft starts or variable frequency drives.
    Keep us posted on how it works and how you're doing. We are probably sticking it out here in New Port Richey, but will know more in the morning. Right now, it looks like you're almost dead center in Irma's crosshairs.
  18. benkhanobi
    benkhanobi Member
    123
    50
    SW Florida
    I have a 800 watt (900 watt peak), 2 cycle engine generator that will run a 5000 watt A/C or a 700 watt microwave= take your pick. I wish that 1.2 gal tank was 1.5 gal. then it would run for 10 hrs= all night long.
    I have a 5500 watt generator, that has 2 male end 115v plugs on the 230 power cord- I wired a double duplex outlet to the bottom of my house panel- the ivory outlet is on one phase and the brown outlet on the other phase. All I need to do is turn off the main breaker, plug the cord into the outlets and start the generator. I can run two window A/C and my fridge, freezer, TV and a few lights on that one generator. The small 800 watt one is a back up. Looks like I may have to fire up the generator for at least a day, maybe two, due to Irma passing 50-60 miles from me.
    Mark
    retired electrician from UAW and IBEW
    FireFighterHill likes this.
  19. Sam Spade
    2,036
    1,024
    2017 Prius c
    No it won't. Maybe you meant to say 5000 BTU ?? ;)
  20. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    An 800 watt generator is good for lights, maybe a radio or a small TV. Or a couple of fans. I have a bunch of Hitachi batteries and flashlights. You could run a couple of chargers, for less than 500 watts. Not an A/C certainly. A portable hair dryer draws 1500 watts. As for running a 3000 watt inverter off a Gen 1 Prius with two deep cycle batteries, I'm skeptical to say the least.
    It's too late for this set of storms, but Harbor Freight has a 3000/3500 watt generator that's quiet and clean for $699. Buy the extended warranty of course. But it would more likely do what you want it to, for less money and wear & tear on your Prius.
    Good luck with both the storms. I suspect if you're close to the water, Orlando will still be pretty intense.
    jerrymildred likes this.
  21. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Goofy forum software=double post.
    #20 Brian in Tucson, Sep 9, 2017
