Getting ready for my first oil change on this Gen 3 - I have questions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by VFerdman, Jan 23, 2025.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,244
    933
    I have been using the aluminum housing for a while now.
    I also have a washable filter in it.
    Can't forget about my magnetic drain plug. 20240309_130433.jpeg 20250118_121647.jpeg
    VFerdman likes this.
  2. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    Aluminum housing, magnetic drain plug and washabl filter? Toyota engineers spent millions to save us money with most effecient engine oil change parts, went your own ways to reinvent the wheel?!
  3. ASRDogman
    ASRDogman Senior Member
    7,861
    4,004
    364,906 miles and still have the original plastic oil filter housing….
    Grit and Danno5060 like this.
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    To the OP, this Amazon listing includes the oil plug at the top, and o-rings:
    Oil Filter Housing Cap Assembly with Oil Plug Drain Compatible with Toyota Avalon Camry Corolla Highlander Matrix Prius RAV4 Sienna Tacoma Venza Replace 15620-40030 1562040030 https://a.co/d/7wI6MfT
    Disregard the description that mentions Camry's, etc. The part number is for the smaller housing that fits Prius, Corolla, etc.
    SM-G781V ?
  5. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    BAM!!!
  6. AzusaPrius
    2,244
    933
    Also there is this handy tool that prevents overtightening that I use from
    http://klickwrench.com and you could save some cash by using code "azusa"
  7. Mendel Leisk
    41,967
    Or just use a torque wrench. Stock oil filter is 18 (ft/lb), spin-on 13.
    Grit and xliderider like this.
  8. xliderider
    8,140
    3,277
    Honolulu, HI
    The aluminum housing turns down, then it hits a positive stop making it impossible to tighten further. Even if it is tightened to the stop point, it is easily removed later by hand or with a cap wrench.
    SM-G781V ?
  9. VFerdman
    VFerdman Senior Member
    1,194
    1,218
    Western Massachusetts
    I have been doing my own car maintenance since 1980's and by now I really do not need any devices other than those that are part of my body to prevent over-tightening oil filters and drain plugs. Things that actually need proper torque I do with a torque wrench (like lug nuts, etc.). As long as I was the one who tightened the filter last time, it will come off easily and without drama. Oil filters in general do not need a lot of torque since there is plenty of thread and gasket to seal the oil in. Just tighten enough to prevent loosening due to vibration. With spin on filters, the rule of thumb is tighten by hand until the gasket seats and then quarter turn after that. That has worked for me for many decades.
    BiomedO1 and Danno5060 like this.
  10. CR94
    CR94 Senior Member
    2,761
    1,210
    Northwestern S.C.
    You won't need the spin-on conversion or the aluminum cap or a stronger cap wrench than the cheap stamped-steel kind, IF---and only if---you'll never be removing the cap after someone has overtightened it.
    I've never had any difficulty removing the cap when I was the last person who changed the filter. One of the two times after the dealer did it, it presented no difficulties. The other time after a dealer change, I broke my stamped cap wrench trying to get the thing loose. Then I bought a forged steel tool, and eventually got the cap off after a struggle with a breaker bar on the tool.
    The way the o-ring seals the cap to the engine does not depend on high tightening torque to seal reliably, as long as the flange on the cap is seated all the way to the corresponding surface. They make the tightness spec as high as they do only to be certain that happens even in case tolerances on the gasket and other parts stack up in such a way that there's more friction than usual. Yet there are careless people in shops putting the caps on with impact wrenches.
    One reason cartridge filters cost more than corresponding spin-ons is that quality control on them is tighter, because the manufacturer knows you can easily inspect the integrity of the filter media both before and after use. I like being able to see it.
    #30 CR94, Feb 5, 2025
  11. BiomedO1
    BiomedO1 Senior Member
    4,273
    2,236
    Left Coast
    I also just crank them down by hand, if I can't get a good grip on the filter - I'll crank down with the filter cup, NO ratchet or wrench.
    I do use a wrench on the drain plug, but I've never over tighten or stripped them.
    VFerdman and CR94 like this.
  12. Mendel Leisk
    41,967
    Toyotas repair manual spec an amount of rotation and a torque. With the spin-on (fresh in my mind since I’ve done the conversion) the two values are 3/4 (of a rotation after seated) and 13 (ft/lb).
    I’ve spun it on till seated, put a Sharpie mark at 6 o’clock, torqued to spec, and found the mark had rotated to 3 o’clock.
    In short: the specs jive. It takes a minuscule extra effort to follow either. It is also roughly 50% more than I could achieve without a tool providing leverage. It is never exceptionally difficult to subsequently break loose.
    #32 Mendel Leisk, Feb 6, 2025
