Getting ready to do some fluid drains/fills
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by H00s13r, Sep 5, 2016.
  1. H00s13r
    H00s13r Member
    88
    27
    Indiana-NWI area, US
    Yikes! I hope I never have to do that.
  2. H00s13r
    H00s13r Member
    88
    27
    So now that I have the coolant's and ATF changed, I am wondering when I should do this again? This was the first time these fluids have been changed and the vehicle has a little over 104K miles-I know I should have done the ATF fluid a long time ago and that is my bad. But going forward (especially now that I have experience doing all the work), what recommendations do you guys suggest for changing the ATF fluid again and also the coolant?
    I have read on here that many people recommend or have changed their ATF every 30K or 40K miles, but since I didn't do it until after 100K miles, should I do it again at the 130K mark?
    What about the coolant-does it need to be changed again around that mark or do you think I am good for the life of the car (if it can make it to 175-200K miles)? Let me know your thoughts.
    I do have to say (and maybe it is just me imagining this), but since I did the work the car seems to feel like it is running a little smoother. The car always has been running fine and I have not had any real problems with it or loss in MPG (averages 51+ except winter where it is in upper 40s MPG wise) doing speeds up to 70mph.
  3. Mendel Leisk
    42,314
    These points work much better for me than the proscribed locations for the scissor jack. The latter, along that bottom weld, don't appear to be reiniforced in any way, and a safety stand is very skittish on them.
    These are also 6 ton safety stands, btw, completely unextended, they barely fit. I sometimes have to nudge the car slightly (carefully) to get the driver's side one in. Base to top of cradle dim on these is 15". My floor jack had a theoretical max lift of 21", though I suspect it's actual under-load lift is a little less. It's a cheapo brand 3 ton. (I should trade mark that name, lol.)
    As you can see from the wheel clearance, the lift is pretty good, lots of room for breaker bar. I use one that's about 18" on the transaxle bolts, lots of room.
    #23 Mendel Leisk, Sep 9, 2016
  4. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The consensus here is ATF change at first 30,000 miles, then every 60,000 miles. 30/90/150/210/270/330/390/450...
  5. Mendel Leisk
    42,314
    Maybe good to consider a time element as well? I'm likely going to do it this fall, three years since I last drained it. We're very low mileage, but tri-yearly does not seem onerous to me, and I'm doing an oil change at the same time.
  6. H00s13r
    H00s13r Member
    88
    27
    Thanks guys.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Hoo I feel your pain with the breaker bar. Next time in Lowes or Home D pick up a a piece of 1 inch emt tubing in the electrical aisle they use for electrical circuits. Bring a hacksaw cut it down to pieces if you have a small car as they only sell it in 10 foot pieces. Its the worlds best breaker bar as the tubing slips over the end of a b bar or ratchet. I have that tubing in all sizes...1 foot...2....3 foot you get the idea. I keep a 3 foot piece in the trunk box with a b bar to get the lugs off if the tire goes flat on the road. Its a very cheap breaker bar and can be cut to fit custom spaces.
    I once had to use a 5 foot long piece over a half inch breaker bar to get a hub nut off a P71 Crown Vic I owned to replace the wheel bearing. 32 mm nut thats on at 160 ft lbs. And has to be tightened to 160 ft lbs.
    Good times. I miss that car...loved it. Living room on wheels lol.
  8. H00s13r
    H00s13r Member
    88
    27
    Good tip on the conduit as a breaker bar. Thanks!
  9. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    If you do your own car maintenance, I would advise investing in a Mityvac 7201 fluid extractor :
    This make MANY maintenance tasks a lot easier.
