Getting some inconsistent warning lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rotocub, Jun 9, 2016.
  1. rotocub
    rotocub New Member
    Here
    Two days ago the first sign of a problem was the AC going out, followed by the red warning triangle and check engine lights coming on about 10 minutes later. Checked coolant and topped oil off (it is due for an oil change, btw) and drove about 20 miles home, no problems despite warning lights. Even the AC started working again. A little while after getting home, I started it up......no warning lights. I thought all was good.
    Yesterday, no issues. Didn't drive more than about 15 miles though.
    Today, took roughly a 25 mile roundtrip with no problems. Made the exact same roundtrip about 2 hours later and the red warning, VSC, brake system and check engine lights all came on (see pic) about 10 miles into the trip. I immediately turned AC off to remove that stress. No changes in car's behavior, however. Made it back home, turned car off and waited about 20 minutes. Turned it back on and only the red warning and check engine lights came on. 2 hours later....same two lights are still on.
    Any ideas?
    52,748
    welcome! check the 12 volt health. if that's not it, go to toyota and have the codes read, or pick up a mini vci with toyota tech stream software, an old laptop and read them yourself.
    how many miles on her?
  3. rotocub
    rotocub New Member
    Here
    Sorry, meant to include that in the OP...
    199k
  4. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    A/C is only about 9A or so. It's a relatively low load compared to driving. If the engine is running, it pulls almost all its power from MG1 and has no affect on the battery.
    If you're hot, so is the battery.
    The only reason you shouldn't run the a/c is if it's use would make you too cold for comfort.
  5. bisco
    52,748
    hybrid battery also a possibility at that mileage.
  6. rotocub
    rotocub New Member
    Here
    Please no, please no.....
  7. bisco
    52,748
    praying for you.(y)
  8. rotocub
    rotocub New Member
    Here
    Latest uodate..,,,,.
    A local Toyota hybrid specialist (who worked 9 years for Toyota) ran diags and got inconsistent codes. He proposed that there's a good chance the problem is related to one of the issues (cooling system/water pump) covered under a recall for my VIN.
    Appt. with the local dealer is set for Tuesday AM to address all recall issues.
    We'll see...........
  9. rotocub
    rotocub New Member
    Here
    BTW....thank you. :)
  10. rotocub
    rotocub New Member
    Here
    Picked her up yesterday evening from the dealership with three recall issues addressed (steering, engine cooling and gas pedal). Warning lights are gone.....so far.......
  11. bisco
    52,748
    congrats, all the best!(y)
