getting the best PHEV kit
Discussion in 'Prius PHEV Plug-In Modifications' started by nohoprius, Aug 9, 2011.
  1. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    Don't know where you got the idea Enginer uses NIMH batteries. They use LiFePO4 cells.
    Now the Enginer system (and most others that don't actually replace the Prius battery) feed electricity one way or another into the Prius NIMH battery. It's just that the low-end Enginer systems 'trickle' charge the Prius battery while other systems are more robust in supplying added power, and so they cost more.
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    Hymotion and Plugin Supply are assembled in the US and shipped from the US. PIS's batteries are made in China. I think Hymotion's batteries are built in the US. Enginer kits use LiFePo4 cells. They never used NiMh. The only PHEV kit I know that uses NiMh is Plugin Conversion Corp. Their kit runs about 14-16K. If you want to get down to the nitty gritty, everything is made in China.
  3. __-_-_-__
    __-_-_-__ Junior Member
    Portugal
    you are totally right. I'm very sorry for my confusion. Do you known what brand they use? What type? Can we use other type of batteries with the kits? Like with more capacity?
    Here's a comparative: (can't post links -.- )
    www dot eaa-phev.org /wiki/
    Prius_PHEV# Kits_and_Conversions
    so, what are the main differences between Hymotion, Plugin Supply and Engineer kits?
  4. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    114
    Enginer(DC-DC converter based)2kw,4kw, 8kw uses LifePo4 realforce ss batt box(I think pouch type).
    Hymotion(converter based too)
    PIS(contactor based) 4kw and 10kw use GBS Prismatic LifePo4.
    You can search youtube, mfg websites, eaa phev to see some of the different PHEV products
  5. cproaudio
    2,401
    758
    CA
    The batteries used on current Enginer kit are RFE pouch cells. There are 4 20ah cells wired in parallel per series. There are 16 series that makes the pack 53.3V when charged. The true capacity of Enginer 4KW kit is actually 4.2-4.3KW. Hymotion and Enginer are converter based while plugin supply is contactor based. PICC just replaces the OEM pack with their own larger NiMh batter pack.
    You can use larger battery packs as long as they're around 53-54v when fully charged and able to discharge up to 120 amps
    2 people like this.
  6. stripedrex
    stripedrex Junior Member
    29
    Smithtown, NY
    Just to clarify I've been talking to Plug In Supply their 10kw system comes from the US their 4kw system comes from China. Not sure why they did that but that was the breakdown I was given. Another interesting note for anyone interested you can start with a 4kw PIS and add another 4kw for an 8kw system still maintaining cargo area. I have an 8 mile commute to work but expect to drive this car (of which I don't have yet =p) all the time through the weekend so I can see myself bumping to an 8 by adding another 4kw. In looking at this consider the weight impacts as well. I'm certain performance will be more sluggish and wobbly with 300 lbs of battery in the back (that's like having 2 adults in the back all the time). Another reason I'm thinking of going 4kw (100lbs).
    Food for thought.
  7. mrbigh
    3,686
    699
    Long Island, NY
    Hi stripedrex, welcome to Priuschat.
    I noticed that you are local to me. If interested and need of some expertise in PHEV conversions, contact me through LIPOG.ORG; I support a local group of Prius owners (Long Island and surroundings)
    ...and now, the USA average adult people weight should be 200Lb and above, so you can keep puting more batteries
