Getting the U0155 code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Steelholder, May 5, 2023.
  1. Steelholder
    Steelholder Junior Member
    73
    17
    Encino
    Hey all, after an oil change yesterday I noticed that my gas meter had gone from around 3/4 full to fully topped off. Seemed a bit strange but ignored it until my drive this morning, it was still full after about a 20 mile drive(has gone down one notch since). It's throwing code U0155. Some type of loss of communication, aby tips on where to start?
  2. ChapmanF
    18,943
    U0155 is some ECU in the car saying it can't communicate with the meter cluster.
    Turns out there are several ECUs in the car that normally do communicate with the cluster (the power management control ECU, the body ECU, the smart key ECU, and the air conditioning "amplifier").
    So it's useful to know, not just that you have a U0155 code, but which ECU in the car is saying it (or which ones, if more than one). Then you know which things can't communicate with each other, and then it's possible to start looking at the network diagram in the repair manual to think about where such a problem might be.
    Some scan tools tell you which ECUs reported which codes, but others just report all the trouble codes they saw, glommed together in one list. For this kind of issue, if you have the latter kind of scan tool, it may be worthwhile to upgrade.
