Give up charging during winter?
Discussion in 'Prime Main Forum (2017-2022)' started by Metalmanstan, Dec 14, 2017.
  1. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    This past week our average temperature was -4, my point that just puts everything in reverse. EV’s just aren’t ideal in extreme climates for that reason. 3.5-4 months of frigid temps and snow.
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Neither are traditional vehicles.
    That's why a plug-in hybrid makes such an nice choice. It provides a means of reducing losses... unless you give up charging.
    Also, single-digit/sub-zero temperatures only last a few weeks. The rest of the winter, you'll still see outstanding efficiency.
  3. 4rpr15
    1,056
    375
    WI
    Our sub zero temps actually last through February. They claim that this will be one our coldest winters. That worries me for obvious reasons.
  4. JTEM
    JTEM Member
    59
    35
    Boston, MA
    Yep, last few days have been brutal in the Greater Boston area. With temperatures in the single digit, even if I set the temperature at 62 degrees F, in ICE kicked in. Battery charge depleted in 15 miles or so. I have to charge it a couple of times to see if I can see a pattern here with what is going on.
    JT
    4rpr15 likes this.
  5. 4rpr15
    1,056
    375
    WI
    I’m with you there. Freezing and getting sick just to try and get EV miles just isn’t my cup of tea I guess. I may made a mistake here on this purchase.
  6. john1701a
    12,840
    5,312
    58
    Why are you fighting it?
    Just let the engine run for heat.
    The system will still take advantage of plug-supplied electricity, just not as much as in the warmer months.
    There's no need. You already know why. The heat-pump has a temperature threshold of 14°F.
    Anything colder than that will trigger the engine to start to supply cabin heat.
  7. 4rpr15
    1,056
    375
    WI
    Why? This entire week I may have gotten 25-30 EV miles total. Keep in mind that M-F I have a 19 mile round trip to work. That’s how cold it was. No matter I did EV just wouldn’t kick in. It was too cold. My point was that this is going I last through February....at least.
  8. john1701a
    12,840
    5,312
    58
    The extreme temperatures will *NOT* be continuous for that long. It just plain does not happen here in Minnesota. Your climate in Wisconsin is quite similar. We'll get ups & downs. When it hits 20, you'll see EV again...
    You'll rejoice with the arrival of spring as if you were a young child reaching the end of a school year. Yippee!
    4rpr15 likes this.
  9. JTEM
    JTEM Member
    59
    35
    Boston, MA
    Given the low effective mileage from a full charge of battery in this weather, it does not make economic sense to use the battery where I am based. Unless of course you are able to use a free charging station.
    JT
    4rpr15 likes this.
  10. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    If I remember from the number @bisco put up, even during warmer days, Boston residents are not going to break even using electric vs gas. So, if economic was the only consideration, you would have to find cheaper electricity or wish for higher gas price. For me, even if I can't use EV during extreme cold, PRIME purchase was economically sound. For the price of Prius One, I got far better car equivalent of Prius Three-Four.
    #90 Salamander_King, Dec 31, 2017
    jerrymildred and bisco like this.
  11. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    Still beats anything else on the road.
    heiwa and jerrymildred like this.
  12. bisco
    52,803
    -23? :eek: how far off average is that? i thought we had it bad, i've never seen a stretch like this.
  13. JTEM
    JTEM Member
    59
    35
    Boston, MA
    I am not questioning my decision to buy the Prime. Just that the economics of charging gets really out of whack.
    JT
  14. bisco
    52,803
    no question. it's bad around here in the good weather, but even worse now. i'm barely getting 10 miles, but i wonder if the battery is taking a full charge? perhaps the cost differential between warm and cold isn't as bad as it appears.
  15. john1701a
    12,840
    5,312
    58
    Lots more HV blending than EV in the winter.
  16. bisco
    52,803
    what does that mean john? i'm driving strictly ev, but i'm wondering if the battery takes as much charge as in warmer weather?
  17. john1701a
    12,840
    5,312
    58
    Electrical resistance increases significantly at sub-freezing temperatures... same thing we've been dealing with for many years now... without an electric heater though, which you now have to also zap away capacity.
    To see the impact, measure your drive without the heat on.
  18. bisco
    52,803
    that's the only way i can measure it. it's a pip, no heat unless the engine is running.
  19. john1701a
    12,840
    5,312
    58
    You should know better than to contribute to newbie confusion, especially after so many years here. That previous post of yours was extremely misleading.
    Don't post PIP (2012-2015) information on a PRIME (2017-) thread without explicitly stating which generation you are talking about.
  20. bisco
    52,803
    sorry i blew your mind.:cool:
