Glass spots - how do you remove them?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Wraiththe, Dec 19, 2021.
  1. fuzzy1
    10,710
    Human eyeballs at the scene with stereoscopic vision, enhanced by the ability to easily change viewing angle, can readily determine which of the several glass surfaces those spots are on, far better than we remote forum readers can possibly do. I see no good reason to challenge the OP on this.
  2. Tahsin Shamma
    Tahsin Shamma New Member
    16
    Massachusetts
    2022 Prius Prime
    Found this online. Could help...
    I'm too new to post the link. Look for
    How to Remove Water Spots and Water Etching on Paint and Glass
    On the site adamspolishes
    Wraiththe likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    It is not a "challenge".
    It is an attempt to do some rational analysis of all the data that has been supplied.
    It is an attempt to be helpful.......as opposed to your comment which just stirs up trouble.
    Then.......do you NOT agree that something is being overlooked, since he lists at least 10 different methods of "cleaning", NONE of which has done any significant good ??????
  4. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    I did not ignore it. I said it was not funny... referring to replacing the glass. I did consult a glass company. They said we don't do that, we just install and remove.
    I probably need to talk to a glass cleaning company... or a scientist. I bet there is some kind of trick where you could put the window in a solution and run a current through it to draw the particles away from the glass and onto a charged plate. (sounds good in theory.)
  5. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    I forgot to mention that I tried this already... but I not exactly the same way. I will try it again.
    I tried duragloss too, but hand, but it did not make a difference
  6. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    I have tried:
    claying the windows.
    Invisible shield,
    Rain-x 1 in 2 cleaner
    Rain-X water-spot remover,
    Vinegar and water,
    Coca cola,
    50/50 wheel cleaner and water,
    White magic eraser,
    Isopropanol,
    Nail polish remover. (acetone)
    Meguiar's paint cleaner,
    Comet shower cleaner,
    Scrubbing bubbles bath and shower cleaner,
    A razor blade,
    Weiman's Ceramic and glass top cleaner.
    Duragloss
    something else I cannot remember.
    So far I do not believe I have scratched the glass.
    The Weiman's worked best.
    The spots are not on the inside of the window, there is no aftermarket tinting.
    I may try to get a new tube of Rain-x water-spot remover.
    Chemical guys gel glass spot remover comes tomorrow.w
    If I get an DA or orbital polisher... I will try that as well.
  7. fuzzy1
    10,710
    You actually wrote:
    While that certainly is a possibility to explore, your "logical conclusion" is an example of the logical fallacy "jumping to conclusions". It prematurely excludes yet other possibilities.
    Your declaration that the spots are inside, not outside, collides with several clues in OP's second and third basepost images that strongly suggest these spots are first surface reflections (nearest optical surface, i.e. outside), not a second or tertiary surface (e.g. inside).
    Yes, I agree that something has been overlooked. Another poster's contribution suggests additional ideas to explore:
    Found here:
    https://adamspolishes.com/pages/how-to-remove-water-spots
    It would seem that OP's work so far ought to have taken care of raised surface spots such as "water spot" or the top half of "bonded minerals". But instead of immediately jumping to a conclusion that the spots must therefore be second-surface, this illustration clearly shows two additional first-surface issues worthy of exploration: the bottom half of "bonded minerals" possibly embodied in the glass, and also "etching" into the glass.
    Even if those ideas don't bear fruit, it is still not logical to jump to a conclusion that this must be a second-surface matter. Especially now that OP subsequently clarified that these are not inside.
    "disagreeing with Sam Spade" == "stirring up trouble". When there is reasonable basis to do so, so be it.
    Raytheeagle likes this.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    Did you have the car WITH you at the time, so that they could LOOK at it ?
    Maybe a company that does tinting would be a better choice.
    Or a different glass company.
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    I said it was a reasonable conclusion, not a guaranteed one.
    And the WAY that you disagree with people often is insulting and demeaning, no matter who it is.
    2010moneypit? likes this.
  10. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    Is better to ask than assume someone is inept. Also, as these threads get long, important details and data gets overlooked... hence the comments disregarding previous mentions. It is wasteful... but it is going to happen. My hopes are that the glass is not etched... and if it is... well guess I am going to have to look up the best ways to deal with that short of replacement, because that is not going to happen. What I want is to be able to see out the windows in the perfect bad weather situations: ie, when the temp is just cool enough for a fog or light mist to stick to the windows and enhance the deposits and make it impossible to see out the windows correctly with oncoming headlights or when driving towards the sun. Micro scratches from various methods would also destroy the windshield making it impossible to see when driving towards bright lights due to refractions. Furthermore, the windshield and replacement service on a gen 4 Prius is EXTREMELY expensive due to the antennas and electronics in it.
    Hence all responses are appreciated and filtered appropriately... despite any lack of tact... misguided good intentions... or solid basis.
    I will post results... as should anyone who posts here, so there can be closure and a positive learned result that benefits others with the same question in the future. I have noticed a lot of posts here with questions and no final answer... which is most unfortunate.
  11. fuzzy1
    10,710
    It is just one of numerous ideas to check out. That doesn't make it ready for any sort of conclusion.
    Should I be emulating this style instead?:
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    Indeed.
    Another idea/clarification:
    Look for a "window glass/mirror store" in your area that does repairs.
    They often have people there who really ARE glass experts and not just broken glass changers.
  13. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
  14. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    There are not many here. All closed today... one place. However...
    I am impressed with chemical guys waterspot remover gel so far. Huge difference!
    So hard to see on phone... but the left side of the window had it applied. Suprised at how dirty they are asside from spots.
    dig4dirt likes this.
  15. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    you need to clay.
  16. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    I have mentioned more than once that I have already tried a clay bar... with no success.
  17. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    What about a hammer? Then replace the glass when done.
    Pulse07 likes this.
  18. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    These banal comments are wasteful... and make the thread more tedious to read through for future use.
  19. sam spade 2
    7,035
    2,804
    2017 Prius c
    No more wasteful than the banal comments complaining about it. :whistle:
    It just goes with the territory.
    Learn to live with it.
  20. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    If you are not interested, why not just go elsewhere?
