Glitchy wireless Android Auto on my Base 2024 Prime.
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by DOHCtor, May 18, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
  2. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I don't like to use the wireless charging slot. It's not a good spot for cell reception, and I like to keep an eye on my phone screen.
    I use a wireless charger cradle that fits neatly to the left of the instrument panel. It won't get me a ticket for distracted driving either.
  3. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    Don't use the slot either. Have a magnetic phone mount attached to the tray lid of the center console. Works quite well.
  4. Sharol
    Sharol Member
    162
    76
    Kansas, USA
    2023 Prius
    I have an issue I haven't seen here. If there is a better place to post it, please advise me.
    I am having a problem answering the phone when the phone is plugged into the data port. The calls mostly go to the phone instead of the audio system. Since I have drop out issues in some areas where I regularly drive, I usually plug in the data cable when heading into town. I'm assuming it is a user error (because usually it is). What in the heck do I press to answer the phone and have it answered through Android Auto? There is the green answer button on the head screen, the phone answer button on the steering wheel, and it seems like there is a third option, none of which work with any kind of regularity. If the phone is connected wirelessly, the answered call goes to the AA in the car (which makes no sense to me).
    On occasion, I have the same problem calling out. I long press the audio button on the steering wheel, speak the command, and the voice says (through the speakers) calling xxxxx. When it connects, it is on the phone instead of the car system.
    I have the Samsung s20 phone and the advanced audio system on the car if that makes any difference.
  5. radsaq
    radsaq Junior Member
    28
    Virginia, USA
    2024 Prius
    As a first step, I'd connect the phone to the car both wired and wirelessly and verify that in Settings -> Connected devices on your phone in both cases that all options are enabled for the car's access.
  6. Sharol
    Sharol Member
    162
    76
    Kansas, USA
    2023 Prius
    Good idea. I'll check that out.
  7. CeruleanBlue
    CeruleanBlue Member
    67
    28
    NC Triangle
    2023 Prius
    The more time I spend with AA, the stranger things get with start-up. Weird behaviors with stop and go restarts on road trips yesterday. It must be software address space getting hosed with such usage. Overall it works for navigation purposes, which is about all I use it for, and beats paying for a navigation sub. But flakey.
  8. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Any app that could show a video on the screen is disabled by Android Auto. Joe Rogan podcasts on Spotify are audio only.
  9. Hammersmith
    Hammersmith Senior Member
    2,477
    2,536
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Only true if you choose it to be. There are alternatives.
  10. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Have you tried Wheelpal?
  11. Hammersmith
    2,477
    2,536
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Nope. That's for iPhones and I have an Android. I use CarStream installed via AAAD. I'm lazily trying to get a full mirroring app to work, but I don't really need it, so I've spend hardly any time on the project. Maybe someday I'll spend more than 15min to try to get one to work. Until then, CarStream does 99.9% of what I need.
  12. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I installed Carstream last year, but it wouldn't appear on my system, apparently disabled by Google Auto. Has it been updated to work now?
  13. Hammersmith
    2,477
    2,536
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Mine's always worked. Any issue you have is with your phone, not the car. I think there was a setting I had to select by switching the phone into developer mode first. You need to spend some time watching videos of people installing it or reading reddit threads about successful installs. It's been almost two years since I first got it to work, so I don't remember the particulars.
  14. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Well, I'm ready to get rid of it. I don't have a developer mode, and the app won't go past connecting to the car with Bluetooth. It just does nothing.
  15. Hammersmith
    2,477
    2,536
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Anyone can put their phone into developer mode(at least for Android; no experience with Apple). I think it varies from phone brand to phone brand, but I have to go to a particular screen inside Settings and tap a certain spot 7 times. All you have to do it search for your phone model on google and include "developer mode" in the search to find the instructions for your particular phone.
