glove box light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DRogers, Mar 22, 2015.
  1. DRogers
    DRogers Junior Member
    Ottawa Ontario
    Sorry I've done a search but can't find anything. I just noticed the other day on my ride home after dark that the lower glove box light is always on, even when the door is closed. I never noticed this before and it seem a little strange for a hybrid car to have a light on for no reason, I don't see a switch to shut the light off when the glove box door closes, I don't see anyway to shut this light off, I realize it wouldn't draw more power but any power is to much in a hybrid. so is this normal for the light to be be always?
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    If it is an LED, the drain is insignificant.
    Even if it is a small incandescent, it might cost you a gallon of gas every TEN years or so to light it all the time.
    I would hope that it goes off with the ignition.
  3. Patrick Wong
    18,210
    6,517
    The way to shut off that light is to turn off the vehicle lights. When the lights are on, that little light is on as well. It saves the cost and weight of a switch in the glove box door, don't worry about the current drain.
    Dino33ca likes this.
  4. Easy Rider 2
    1,584
    258
    Ocala, FL
    I don't think I like that design either.
    It gets "dark" in the glove box before it gets dark enough for the headlights. :)
  5. DRogers
    Ottawa Ontario
    OK it does go off with the ignition, so I will forget about it. Just never saw it on before and all of a sudden I noticed it, now I can't stop looking at the crack around the door where I see light creeping out. LOL thanks.
  6. Easy Rider 2
    1,584
    258
    Ocala, FL
    It could be worse.
    My C doesn't HAVE a light in the glove box OR the center console.
    Or overhead in the back seat for that matter. :(
  7. Purrius
    Purrius Member
    172
    50
    Northeastern US
    I replaced the LED and it still wasn't working. I was looking up fuse diagrams and stumbled on your comment. My gosh you just saved me from what I can only assume would have been a massive self-inflicted nightmare.
    ╭( ๐_๐)╮
