Glove box won't shut
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Anklebreakers, Jun 15, 2012.
Glovebox repair needed
Poll closed Jun 22, 2012.
  1. clip broke on Glovebox
    0 vote(s)
    0.0%
  2. suggestive tools needed
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Anklebreakers
    Anklebreakers Junior Member
    Wisconsin
    Any help to repair or relace the hardware for the lower Glovebox latch for 2004 Prius would be greatly appreciated.
  2. Howieau
    Howieau New Member
    Remove the grey plastic bar that separates the top and bottom boxes.
    It comes off with a little pressure.I used a small slotted screwdriver and pried the side and it came off easily. You will see the latch.it controls both boxes.
    It looks easy to take off... 3 phillip head screws.
    The problem i have is ..can't find the screw that holds the buttons that operate the latch.. Help someone?
    Thanks
  3. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
    My lower box won't shut tonight on the way to work tonight! It feels like something is wedged in it and won't let it shut all the way.... I've looked all around and cleared everything out of it to make sure nothing is stopping it from shutting but I see nor do I feel anything blocking it! Any ideas? Mines 2012 BTW Generation III
    #3 Accordlayingkit, Jul 21, 2014
  4. JC91006
    16,936
    8,647
    There is nothing mechanical about this glove box, remove the entire thing (as if you were installing a cabin filter), then see what's stuck in it.
  5. Accordlayingkit
    1,618
    1,748
    377
