Glue/paste squeezing out from the engine.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LulzChicken, Jan 6, 2012.
  1. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Hey guys - I recently saw what appears to be glue or some type of paste coming out of my engine. I think it may have been there the entire life of the car, but I'm not sure. Is this something I should be worried about, or should I let it slide?
  2. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Mine is the same way, almost in the same spot just over to the left of there.
  3. frodoz737
    frodoz737 Top Wrench
    4,802
    2,560
    33
    Looks like RTV Gasket (sealant).
  4. Colm--
    Colm-- New Member
    Delaware
    frodoz737 is correct. That's sealant applied where the perimeter seal overlaps.
  5. LulzChicken
    791
    135
    Alabama
    Thank you guys for the input. Should I have them do anything about this? I don't want more issues arising from them trying to fix it if I can just leave it alone.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Leave it alone.
    Tom
  7. LulzChicken
    791
    135
    Alabama
    That's just what I'll do! Thanks! Could I pull off the gunk that squeezed out, though, so it doesn't look bad?
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    take a razor blade and carefully cut it off flush with the block...
  9. BlizzardPearlV
    BlizzardPearlV Junior Member
    35
  10. LulzChicken
    791
    135
    Alabama
    I just can't believe I wouldn't have noticed this earlier from all the time I have looked at my engine compartment. This would have had to of happened during manufacturing, right? As in, it would have had to be there the life of the car, am I right? I just hope it doesn't cause any problems. I just don't recall that being there, and I don't know why it all of a sudden oozed out.
  11. HyperFX
    HyperFX NIMFY (not in my front yard)
    81
    35
    30
    New Jersey
    Although it may be tempting, do not place it on a toothbrush and do not brush your teeth with it.
    3 people like this.
  12. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Mine has it too. Purchased in Australia.
  13. frodoz737
    4,802
    2,560
    33
    It's been there since the engine assembly was put together. Forget about it.
  14. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    First I would like to thank you for posting a pic of the issue. Way to many people post things like this without a pic. Everyone has a cell phone with a camera, why not use it.
    Here is a pic of mine.
    Mine looks identical except my engine is showing a lot more wear after 73,000 miles in Cleveland’s salty winters.
  15. LulzChicken
    791
    135
    Alabama
    Great! This is re-assuring to me. I'll just leave it be. Thank you for posting guys! Everyone who posts in my thread gets a "Thanks"! Also, Judgeless, I agree. A picture is so much better than just words alone. There isn't much of an excuse NOT to include a picture now days. Cheers!
  16. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Mine is the same way. Normal
  17. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    I took a second look. It is exactly like yours. Don't cut, it leave it.
    If you want, on your next dealer visit make them put a comment on your account that you have this and if any thing happens you have a record of it before the expiration of 36,000 miles.
  18. Mendel Leisk
    42,343
    It's normal; I'd leave it as-is. Liquid gasket of some sort has been applied to a joint. The only way to ensure none squeezes out is to not apply enough.
  19. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Just a comment to those saying leave it.
    If it's just a lump that has squeazed out and is hanging there? As it appears in the photos. Why would cutting it and removing it hurt anything? It obviously isn't doing anything just hanging there.
    I wouldn't worry about it. But I'd remove it.
  20. Den49
    Den49 Member
    498
    272
    Maryland
    The "squeeze-out" of this type of form-a-gasket material is intended. It acts as a lock to prevent the gasket from shifting or loosening and leaking.
    Don't cut it off.
