Going Crazy... Can't remove front bumper/headlight assembly :(((
Discussion in 'Generation 1 Prius Discussion' started by Dare.Devin, Sep 11, 2015.
  1. Dare.Devin
    Dare.Devin Junior Member
    Garden Grove, California
    2002 Prius
    I
    Trying to loosen the front bumper so I can remove the headlight assembly to replace the inverter pump. I removed every bolt I could find but there's the one that's attaching the fender to the bumper, its too far in to reach. Can anyone please give me some tips or point me to how I can remove the headlight assembly or front bumper? I looked everywhere on google and couldn't find anything so I just went for it.
  2. JC91006
    16,939
    8,647
    There is only 1 bolt that's at the very top of the fender, flip the inner liner out of the way and unbolt. It's nearly at the fender 12 o'clock position
  3. Dare.Devin
    2002 Prius
    I
    GOT IT! DONE! Bada bing bada boom! Thanks JC!!
  4. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    When doing the inverter pump unbolt it from the frame rail first, then move it around to unhook the electrical connection and the hose clamps. There should be marks on the hoses to orientate them up the correct way on the new pump. Once the clamps are on then put the pump in place and bolt it down. Bleed it. Drive the car 5 miles or so then bleed it again.
