Going downhill in b mode, gets fast quickly! Is this usual?
Discussion in 'Prius c Main Forum' started by Laurenparkranger, Mar 12, 2018.
  1. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Been there (not the exact place), but I was in front, towing a 34’ trailer, praying that the idiots brakes behind me would hold on long enough for my wife and I to get out of his way. We did, but he didn’t survive the rest of the grade. Neither did his family.
  2. ChapmanF
    19,032
    He wasn't trying to perform a miracle, he was taking a descent at a rate of gained energy that exceeded B mode's ability to sink it.
    You make "decipher the kinetic energy equation" sound like some kind of weird alchemy.
    If you teach somebody he could slow down until his rate of energy gain is within the car's capacity to sink it (because the gain is proportional to his speed, there's the whole "cipher"), then you are actually teaching him physics, which will allow him to suit his actions to the tools and conditions at hand, and get the results he wants. ("Teach a man to fish")
    "Give a man a fish" would be if you got in his car and drove down the hill at a workable speed in B mode for him, but didn't explain how you did it.
    Waving your hands and saying he didn't get the results he wanted because the car's incapable of it, he wanted miracles, he's an idiot and will wreck his car, is taking the fish off his plate and leaving hairballs there, all while mouthing words about the laws of physics.
  3. Leadfoot J. McCoalroller
    8,290
    7,805
    Pennsylvania
    2018 Prius c
    @Doug McC I did say I could sympathize with your frustration...
    ...but I think he's got you on that one. The fundamental problem isn't that mountain driving is difficult, it's that we can't schedule everyone's first encounter with it at the same time, and preferably in the past. The n00bs need experience, and the rest of us have to be tolerant and vigilant.
    Doug McC likes this.
  4. fuzzy1
    10,711
    And I'll confirm from having significant experience with each of the three scenarios listed here.
    When I saw and smelled the same situation at the mandatory brake checkpoint on the descent from Pikes Peak, the offender was a Ford pickup with Florida plates. I don't believe anyplace in Florida needs a downshift.
    Quite a while back, a new member here in Hawaii had to replace his overheated friction brakes twice before figuring out that 'advice' from a certain few misinformed flatter-land members here was wrong. Brake pedal regen in D mode was not sufficient on his steep slow 3000+ foot descent. Some hills require B mode to prevent overheated brakes. And even that may not be enough on certain select mountain grades.
  5. Zythryn
    Zythryn Senior Member
    6,412
    4,414
    The amount of regen available is a factor of the amount of empty battery capacity available.
    A Prime should handle the mountains better. A BZ4X better yet.
  6. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    B mode is not just a function of regenerative braking, per the OM:
    ■ About engine braking
    When shift position B is selected, releasing the accelerator pedal will apply engine braking.
    ●When the vehicle is driven at high speeds, compared to ordinary gasoline- fueled vehicles, the engine braking deceleration is felt less than that of other vehicles.
    ●The vehicle can be accelerated even when shift position B is selected.
    B Mode effectively (notice the use of the word effectively does not mean the “same as”) changes the gearing to a lower gear, much the same as Tow Mode does in many pickups.
    My problem here is people making a rather simple process much more complex than it really is.
    In all reality, who really cares how many KW are being generated while descending a steep grade? The simple answer to the OP was the one I gave in describing the safe method of descending such a grade.
    Enough said from me.
  7. Mendel Leisk
    42,354
    I think he was. ;)
  8. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    I just reread the entire thread and I respectfully disagree. From his description, he actually did. His post was a cry for help.
  9. ChapmanF
    19,032
    Kilowatts being the SI unit for power, and the whole question being about "will the car slow down, hold speed, or speed up on this downgrade" being a simple matter of comparing one amount of power to another, the answer to "who cares" will be "anyone who'd like to understand why their car behaves three different ways in three different situations, and how to drive accordingly."
    The fabulous thing about learning some physics is gaining the ability to understand things like that in real life, and use that knowledge to your benefit.
  10. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    It is even better when you can use that knowledge to provide explanations in simple terms to benefit someone else.
  11. ChapmanF
    19,032
    If I ask you to carry a bag of roof shingles from here to there, and you find it tough to lift (I do, but then I'm a nerd), you can probably guess that if I show you two bags of shingles, you might prefer to take them one at a time. And if I show you a half-empty bag, you'll think "no sweat".
    For this, you don't even need to have a number for the weight of the bag, and it doesn't matter whether you're used to those numbers in pounds, stones, or hundredweight. What matters is you know that:
    • there is such a thing as weight
    • more of it makes stuff harder to lift
    • in fact (strict proportion) twice as much makes stuff twice as hard to lift, half as much makes stuff half as hard to lift
    That's it right there for the concepts you need.
    Now, when might you like to know an amount (in some familiar unit, pounds maybe)?
    Well, if you've already got some idea (from the gym, maybe) what amount you're comfortable lifting, you can make some judgments about this bag of stuff before you walk up to it and heave.
    Or, if you've just carried that bag and it felt like work, you can ask "say, what's one of those weigh, anyway?" and remember that, and use it to make judgments about other things later.
    If you know you can make it down a certain grade at a certain speed in B mode and not pick up speed, and you come to another hill that's twice the grade, you'll have to drive half the speed (or use the brakes).
    Or, if you come back to the same grade but you've loaded your Prius to the gills and made it 20% heavier, you'll have to take the hill that much more slowly (or use the brakes).
    We spend our kids' grade school years making sure they will not grow up thinking fractions, multiples, and proportions are scary concepts they can't "decipher".
    It does nobody any favors to come back when they are grown up and try to scare them away from the same concepts then.
  12. Jstampfl
    Jstampfl Junior Member
    25
    Mongolia
    2018 Aqua
    I
    Some of us live in mountainous regions. Brakes matter. I miss the low range in my old Russian jeep. Just have to be careful, go slow. Buy good brakes and rotors
  13. rela
    rela New Member
    2022 Prius
    XLE AWD-e
    My goal was to find the cheapest safe way to go Mammoth or Big bear (or similar) from OC in winter. With snow, but after roads are cleared. Not trying anything crazy, just trying to be safe / not slip.
    I had a Rav4 which did a great job. A friend totaled it, tried a cheaper solution.
    I have an 2022 awd-e prius now, with proper tires. The efficiency is amazing. Most of these drives are not snow, just the last part is icy/snowy. I can live with the limited acceleration. The limited back traction seems to be enough for what I do.
    The downhill part seems to be the only thing I can't work around. Having to hit the breaks when driving downhill in curvy and icy roads is far from ideal. The Rav4 had downshift that would avoid this.
    This is, so far, the only reason I've found for justifying the extra cost (and less efficiency) of the Rav4.
