Going on a 3 month trip, how to avoid a dead 12v battery?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Oct 31, 2010.
  1. ski.dive
    ski.dive Active Member
    865
    224
    Hutchinson Island,FL. Mt. Snow,VT
    OK:
    1] I know I need to turn off the SKS so the battery wont drain, what else should I do to save the 12V battery?
    2] how do I open the door with the SKS turned off when I get
    back?
    3] how do you turn the SKS back on [do I just hit the SKS button again??]
    4] what else will I need to do when I get back in 3 months to get going?
  2. jbgggg
    jbgggg New Member
    Missouri
    I disconnect the negative battery cable from the 12 volt battery. You will loose your radio presets so write them down before disconnecting the battery. My car is in a garage so I put a work glove over the hatch latch so I can open it when I return and reconnect the battery. This has worked well for me. I also make sure to drive the car before disconnecting the batter to make sure the traction battery is charged. Hope this helps.
  3. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Not enough, disconnect the 12v (see above) or attach a "Battery Minder"
    Just press the door unlock button (if the 12v is now connected) on the remote.
    Yes
    If you disconnected the 12v, you will have to reset the radio settings and reinitialize the automatic driver side window opening by fully openning and closing it.
    JeffD
  4. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    Or (just a thought) you could install a new Optima before you go, turn off SKS, and just have a nice trip.
  5. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    57
    Fullerton CA
  6. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    Ask a trusted friend to drive it every couple of weeks. I left mine last Winter for 6 weeks; a friend drove it once after 3 weeks and it was strong a ready to go when I returned.
  7. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    What is SKS? sorry i'm new to Prius..
    and how do you turn it off/on ??
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Smart Key System
    Its the system that senses key fob proximity. It uses power
    when the car is powered off. Although minimal current draw sometimes on prolonged absence it will kill a borderline aux battery. Although, many reports of people going away for 3 months and coming back with no issues but its best to be safe.
    To turn the SKS off there's a button under the steering wheel.
    The major determining factor is if you have ever had to jumpstart your battery just once its not a good candidate for prolonged absence even with the SKS off.
  9. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Come on people! RTFM! The SKS system will turn off by itself after a few days of no use. It is -UNNECESSARY- to turn it off manually.
    For three months, I'd disconnect the battery -ve terminal unless you have a battery tender to leave connected to it. The Prius 12V battery, even when new and/or in good shape is only going to hold enough charge for about 4-5 weeks of no use, SKS or not! This is not only applicable to the Prius as well. Most modern cars will drain the battery over this kind of time interval of no use.
    You WILL have to figure out how you're going to get into the hatch to reconnect the battery. I recommend connecting another 12V source to the boost terminal under the hood to energize the hatch release. A portable boost device is a good choice here, as you can leave it plugged in in your apartment, but even if the car is left at an airport a portable boost device, left on the floor of the car while you are away, should be able to power up the hatch release when connected to the boost terminal.
  10. global hybrid
    global hybrid Prius Intern
    Portland, Oregon. USA
    Every winter our 2008 prius goes into garage storage for three (3) months. 1st, we change insurance coverage to comprehensive only; $$$ savings. 2nd, disconnect the cable from from the battery (10 mm wrench) located on the right side of the trunk. Leave the wrench & work lite close to the work site for ease of reconnection. 3rd, check & clean the cable & terminal connections. 4th, use something to insullate/ separate the terminal & cable from each other. Before closing the hatch I put a shop rag over the lock latch. The key fob then goes into a security container.
  11. ski.dive
    865
    224
    disconnect the cable from from the battery (10 mm wrench) located on the right side of the trunk. Leave the wrench & work lite close to the work site for ease of reconnection. [/QUOTE]
    Why can't you just disconnect the + battery post under the hood?:D
